Offline Carlos
#1 Posted : 01 January 2020 16:56:27(UTC)
Carlos
Hi to all members and Happy New Year:
What's the best way to glue the Cork Roadbed and to be able to unglued and use it again. thank you and regards,
Carlos
Offline Chris6382chris
#2 Posted : 01 January 2020 17:07:03(UTC)
Chris6382chris
Hi Carlos. When I have used cork in the past, before I found Marklin M and then C Track I often found that the cork wasn't worth saving once making changes. Even when using white glue I still found the Cork didn't come up clean after using water.
Chris
thanks 1 user liked this useful post by Chris6382chris
Offline Carlos
#3 Posted : 01 January 2020 22:18:43(UTC)
Carlos
Chris
Thank you Chris for your fast respond.
Carlos
Offline jcrtrains
#4 Posted : 01 January 2020 22:57:24(UTC)
jcrtrains
I nail down the cork. It can come up easily once nailed. However, I also ballast the cork and track with glue. Once that activity is complete, it will not come easily and it is better to start again.
thanks 2 users liked this useful post by jcrtrains
Offline PMPeter
#5 Posted : 02 January 2020 00:58:44(UTC)
PMPeter
I too nail down the cork and it comes up very easy when the nails are removed and in most cases can be reused. However, as previously mentioned, if it is ballasted it most likely is only good to be tossed once it is removed.
#6 Posted : 02 January 2020 10:13:51(UTC)
Don't glue the cork down. The track screws are enough to hold it in place.
Offline Carlos
#7 Posted : 03 January 2020 03:00:19(UTC)
Carlos
Thank you all of you, but are you using the z scale nails?
Carlos
#8 Posted : 03 January 2020 03:26:48(UTC)
Is this a Z Gauge question? If so, it is in the wrong part of the forum.
Offline jcrtrains
#9 Posted : 03 January 2020 14:26:10(UTC)
jcrtrains
Carlos
I am doing this in HO. I use a thinner track nail for the cork.
thanks 1 user liked this useful post by jcrtrains
#10 Posted : 03 January 2020 23:36:15(UTC)
Why not just put some glue at the edges of the cork bed. The track and buildings etc will hold the rest in place. If you want to use the cork again then just cut round the edges and remove them leaving the remainder available for use.
Offline fkowal
#11 Posted : 06 January 2020 02:42:44(UTC)
fkowal
Try Atlas No. 2540 HO & N track nails. They work well for me. They can be easily removed with a small set of pliers with out damaging the cork. The nails are black and blend in with the cork well.
Foam, cork roadbed and track (Small scale)
by Grondeaux 25/06/2023 17:59:18(UTC)
Cork Roadbed (Small scale)
by Manga 12/09/2022 10:30:28(UTC)
This page was generated in 0.672 seconds.
