#1 Posted : 01 January 2020 16:20:09(UTC)
I see in the CS3 where you connect patch cable there is metal connection for the patch cable.
But the question is what kind patch cable do you use to connect the CS3, shielded or unshielded?
#2 Posted : 01 January 2020 19:18:16(UTC)
Whatis on the other end of the patch cable? You do not say what you wish to connect to. The various connections run at different speeds, and shielding requirements will differ according to the speed.
#3 Posted : 01 January 2020 20:47:54(UTC)
Hi Goofy
I think the cable shield is not connected to anything (look in the S88 and in the Link88, the piece to host the Ethernet connector has only 8 contacts for the 4 pairs and is made of plastic.
So, IMO, the cable shield is of little use so why not go for an un-shielded cable (unless the price is similar).
Offline applor
#4 Posted : 02 January 2020 01:35:38(UTC)
applor
shielded is not necessary.
#5 Posted : 02 January 2020 09:39:44(UTC)
I did checked after answers in google.
Yes it will be fine by use unshielded cable too for the Ethernet.
Thanks for the support!
This page was generated in 0.274 seconds.
