Offline twmarklinfan
#1 Posted : 10 December 2019 19:56:12(UTC)
twmarklinfan
Hello all,
I am looking at this loco 37190. It’s not running as smoothly as we would like. Does anyone have an electronic version of the operating manual, in particular the parts relating to lubrication of the axles and worm gears?
Offline Dave Banks
#2 Posted : 10 December 2019 23:31:20(UTC)
Dave Banks
Hello Adrian, could only find this:
https://static.maerklin....ee4d0bcae41434542112.pdf
Apart from a drop of Marklin oil #7149 either side of the axles and oil on the worm gear every 40 hrs of operation.
You can remove the bottom plate with screws on either end if you want to do the job properly.
D.A.Banks
#3 Posted : 11 December 2019 00:51:52(UTC)
twmarklinfan
Thanks Dave.
Very helpful especially the worm gear as I wondered if it may have required the Trix grease. As it turns out I have found an issue with the last axle on the tender which is neither revolving or sliding across when the loco goes around a curve. Although this is a small resistance it would account for poor slow speed running.
Best
Offline Dave Banks
#4 Posted : 11 December 2019 01:00:29(UTC)
Dave Banks
Adrian you do realize that I had to go dig out that loco & give it an impromptu service BigGrin. That gave me 30 mins of great pleasure giving it a through workout Love .
D.A.Banks
Offline bph
#5 Posted : 11 December 2019 12:42:28(UTC)
you can use the manual for the later version 37193
https://static.maerklin.de/damcontent/a1/98/a198487b19e1125376a699a5efd9c0921434542367.pdf
Guest (5)
This page was generated in 0.206 seconds.
