Offline Morlee56
#1 Posted : 04 December 2019 23:40:23(UTC)
Morlee56
We have a S-2937 set. The locomotive is only going in reverse. Any suggestions on how to correct this?
Thank-you
Offline Dave Banks
#2 Posted : 05 December 2019 04:15:49(UTC)
Dave Banks
Have you tried turning the knob to extreme left IE past "0" & releasing it & turn the knob to the right? By doing this the loco should go in the other direction & gain momentum. If not please take the body off the locomotive as per the instruction booklet if you have it & take a photo of the loco. It may be a spring that has come off the reversing switch or some minor adjustment.
https://www.youtube.com/watch?v=zc0YkkiUrkw
Also please see this: https://www.marklin-users.net/fo...237-train-runs-backwards
Edited by user 05 December 2019 22:54:57(UTC)  | Reason: Not specified
D.A.Banks
Offline Morlee56
#3 Posted : 09 December 2019 03:17:48(UTC)
Morlee56
We do not have instructions in English. Do you know where we can get a copy?
We have not been able to get it to go forward. How do you take the body off the locomotive?
Thank-you
#4 Posted : 09 December 2019 05:14:46(UTC)
Thank-you
You were just given instructions, in English in the reply above, how did you get on with that?
Or are you looking for pictures?
Offline Dave Banks
#5 Posted : 09 December 2019 05:22:08(UTC)
Dave Banks
[This is in German but I am sure you can follow what is going on: https://www.youtube.com/watch?v=CRNCLsZ2aNQ
Very important: Remove screw at top of body & take body off. When you replace that screw do not tighten as you will crack the body. Just nip it up carefully. You have been warned Crying
D.A.Banks
This page was generated in 0.254 seconds.
