#1 Posted : 23 November 2019 16:44:56(UTC)
Noticed when recording with the CS3 Plus that when running a loco into a siding and getting it to stop then when then using the procedure the loco stops before the place as per the recording. Tried with other locos various recoding procedures to stop at stations etc but none stopped where required. I can of course use a contact and an event which works but thought I would use the recording feature which I had not used previously.
Anybody else used this and got it to work with locos stopping where required.
Offline Danlake
#2 Posted : 24 November 2019 09:48:33(UTC)
Danlake
Hi David,
I haven’t tried that feature yet with my CS3 as I am mainly using PC software for automation.
But I would imagine the CS3 uses a simple programming logic based on timing and triggers to carry out the pre-recorded automation.
I use quite a sophisticated software (Traincontroller), and they only way I can get accurate stop position is to carry out quite comprehensive profiling of each locomotive. That is running a test where the program measures what speed steps equal what actual speed of that individual locomotive. This feature I believe is not available in CS3, so the CS3 will just give a simple command to slow down to a set speed or initiate a stop. And your braking distance would be set by CV settings in the decoder and not accurately controlled by the software.
So if you want the loco to stop very accurately with CS3 I believe your best bet is to use more occupancy detectors as trigger events. Else there is just too many variables involved that will influence your stopping point.
Best Regards
Lasse
#3 Posted : 24 November 2019 16:59:39(UTC)
Hi David,
Best Regards
Lasse
Thanks for that. I do just use events now but thought I would try the recording feature but unless I am doing something wrong it does not appear to control a loco accurately. Using the loco braking control can help but it is still hit or miss so I probably will not use it. Grateful for your reply
David
This page was generated in 0.210 seconds.
