Offline tommyheadleycox
#1 Posted : 16 November 2019 03:54:48(UTC)
tommyheadleycox
I have a Röwa speisewagen, I think it's 3214. Strange coupler. I can't figure out how to remove it and put in a Märklin coupler. Anybody ever done this?
thanks 1 user liked this useful post by tommyheadleycox
#2 Posted : 16 November 2019 06:03:40(UTC)
tommyheadleycox
Please ignore my previous message. I finally was able to pull the coupler out of its NEM socket. I'd just never encountered one that required so much force to remove.
Offline sjbartels
#3 Posted : 16 November 2019 17:01:42(UTC)
sjbartels
I have several Röwa cars, and you're right, they are extremely hard to remove, they're fixed in there very tightly
thanks 1 user liked this useful post by sjbartels
#4 Posted : 17 November 2019 04:47:20(UTC)
tommyheadleycox
Thanks, it's good to know I wasn't the only one. BTW, which Märklin coupler did you get as a replacement? Here's another reply I got from Stummis Modellbahn Forum:
Hello Thomas,
Röwa had 2 coupling systems.
if the car has a short-coupling kinematics and a removable Ade coupling, it goes with a craft solution. The coupling shaft at RöWa / Ade is slightly lower than the later NEM shaft. You can file off a bit of height at the coupling socket (the two pins that are inserted in the coupling shaft) of the Märklin KK. Then the coupling head fits. But then you will have to file a little bit at the lower edges of the buffer, otherwise the coupling and buffer plate will get stuck.
#5 Posted : 18 November 2019 03:48:30(UTC)
tommyheadleycox
Hello Thomas,
Here are some fotos of the coupler and the empty pocket. I'm hoping that a Märklin 7203 will fit. Is that wishful thinking?outside.jpgattached.jpgdetached.jpg
Offline sjbartels
#6 Posted : 18 November 2019 15:51:54(UTC)
sjbartels
On my Röwa passenger cars, I used 7203 without any apparent issue... BUT they have not been run to truly test them. The Röwa tank cars that I have however, the 7203 did not work and so went ahead and used Märklin 72060 couplers. Mind you, I've had to do the same thing with Piko, and to a lesser extent, Roco, because of the length of the buffers. I really wanted to have only one coupler type across my entire system, but alas that's not going to happen, but settling for two types isn't too bad.
#7 Posted : 19 November 2019 04:23:46(UTC)
tommyheadleycox
Many thanks for the assistance. Much appreciated.
This page was generated in 0.493 seconds.
