Offline QQQ1970
#1 Posted : 24 October 2019 04:18:45(UTC)
QQQ1970
Can CS3 do train detection (showing which train in which block) like Railcom?
#2 Posted : 24 October 2019 07:36:44(UTC)
Train detection is a patent-protected feature of RailCom and mfx cannot do this for legal reasons.
AFAIK there is no RailCom with CS3.
The ECoS is an alternative with RailCom.
PC control and s88 can be used as a workaround that works with CS3 and unmodified locos.
Offline QQQ1970
#3 Posted : 24 October 2019 14:00:17(UTC)
QQQ1970
Thanks for the info. If I use PC software, do I still need CS3 and will it be able to detect which trains at which block?
#4 Posted : 24 October 2019 14:08:35(UTC)
Have you tried JMRI?
Not sure because i do not use PC and control layout via CS3 when i use digital system instead.
Offline geir
#5 Posted : 01 November 2019 17:21:39(UTC)
geir
If you have 3 trains ,you can use magnet +reader and track switch.And logic
1 Trane have 1 magnet
1 Trane have 2 magnet (one on each side)
1 traine have 0 magnet.
This my be an option:
An RFID system consists of two separate components: a tag and a reader. Tags are analogous to barcode labels, and come in different shapes and sizes. The tag contains an antenna connected to a small microchip containing up to two kilobytes of data. The reader, or scanner, functions similarly to a barcode scanner; however, while a barcode scanner uses a laser beam to scan the barcode, an RFID scanner uses electromagnetic waves.
#6 Posted : 01 November 2019 20:07:01(UTC)
If I really wanted to do train-id then using some sort of RFID sensing under the track or even barcodes might be a viable option... it all depends on how many locos you need to track. With PC's you let the software know what is where, and as it routes trains and sees "something show up" where expected, it can logically conclude it must be the thing I sent there.
But the "from cold power off in unknowns state", to determine what is where, thats been done with RFID in chess peices in the 1990s, so it would be a good way to go .. but it would be interesting if someone could develop a circuit that could be attached to each 'block' of isolated track and read out whats in its block (if anything). No solutions there that I'm aware of.
#7 Posted : 01 November 2019 21:33:50(UTC)
Zimo system has loco ID capabilities via their decoders. You can pick up a loco and put it elsewhere on the layout and it knows what it there.
Pretty much superfluous though, as you say, because software can track where things go (and save the state to disk all the time too).
Offline kgsjoqvist
#8 Posted : 01 November 2019 22:07:17(UTC)
kgsjoqvist
Simple answer: No
The CS3 can detect new locos showing up on the track (mfx). But it only knows that it is on the track, not where. To detect trains on the layout you need to add feedback modules (s88) and contacts. They tell the CS3 where a track is occupied, but you still don’t know which train is where. PC software can use this information to find out where the trains are.
Online kiwiAlan
#9 Posted : 02 November 2019 14:18:08(UTC)
Simple answer: No
I suspect that the mfx feedback could tell where the train is, at least to the point of which booster is it on, but because of the patent that covers Railcom Marklin are unable to implement a Railcom like detection (which is what mfx would do) without paying a licensing fee, which they probably do not wish to do.
Offline QQQ1970
#10 Posted : 02 November 2019 15:07:58(UTC)
QQQ1970
I intend to install Traincontroller at some point so my read is I don't need to replace my CS3 with ESU Ecos to do train detection (which train on where).
Offline Danlake
#11 Posted : 02 November 2019 19:51:22(UTC)
Danlake
Correct, Traincontroller from Freiwald software supports both CS2 and CS3.
Best Regards
Lasse
Offline QQQ1970
#12 Posted : 02 November 2019 23:10:19(UTC)
QQQ1970
It is compatible. My question is does Traincontroller add functionality of tracking which train on which track when used with CS3, which does not offer that function?
#13 Posted : 02 November 2019 23:20:48(UTC)
To clarify this a bit.....
I suspect the original question may not have implied automatic train identification.
By detecting trains that move (point detection) one can show what trains are where. i.e. the automatic identification of trains need not be part of the question.
So the question has now evolved to asking if TrainController software can maintain the state information of what train is where, using point detection.
Offline Danlake
#14 Posted : 03 November 2019 00:45:24(UTC)
Danlake
Yes provided you are using some sort of feedback detection. I.e. you e.g. need to buy some S88 feedback modules and have occupancy track detection in the form of e.g. contact tracks.
During startup of the software, you will tell it where the trains are physically located (in which block) and which direction they are pointed it. After that the software will continuously keep track of the train movements. When you shut down the software and start up again it will assume you have left everything as it was and use that as the start up sequence.
It may seems less foul proof that an actual feedback ID that confirms train A is now physically in block X, but this is the concept used by many large exhibition layout and you can run the layout hours on end without any errors. The main thing is that you install a reliable feedback detection system and divided your layout up in a significant amount of blocks.
By the way, check this Traincontroller video to get familiar with the software:
https://m.youtube.com/watch?v=w76-xEN6TSA
Best Regards
Lasse
Offline QQQ1970
#15 Posted : 03 November 2019 01:00:22(UTC)
QQQ1970
Thank you. You answered my question. While not ideal as positive feedback from train decider via Railcom to tell the system, as long as the contact tracks are properly built and have good detection this should be almost foul proof as positive feedback.
At least I don't need to replace CS3 with another command center for this reason.
Thanks for your feedbacks.
Sebastian
thanks 3 users liked this useful post by QQQ1970
Offline stevend
#16 Posted : 05 August 2025 01:54:10(UTC)
stevend
HI,
I saw this old post and thought it would be so nice to have a text box in the CS that we could fill the text from a serial source, with a simple format <message type><ID#1 Byte><ID#1a Byte><Text upto 20 Chars><CR>. That fills out the box on the screen, then we take an output from a RFID source map that to text and feed that into the CS3.
DS
thanks 1 user liked this useful post by stevend
Offline Drongo
#17 Posted : 07 August 2025 07:40:09(UTC)
Drongo
Regarding Traincontroller knowing where a train is located on the layout, there's a footnote that I would like to present.
If you are running a train on a schedule and if a turnout doesn't respond correctly, then Traincontroller loses control of the train. Traincontroller assumes that the turnout is correctly positioned. If you're using Marklin turnout motors and decoders, then you'll have a lot of problems. You just can't trust that the turnout has reacted correctly. I tried Viessmann 4568 turnout motor/decoders and they were better, but still not 100% reliable. I have now installed servo motors and I'm experiencing 100% reliable responses. And the servo motors are far cheaper. The setback, is that they are a little more to install.
Greg
Online pederbc
#18 Posted : 07 August 2025 10:42:11(UTC)
pederbc
I’ve fixed all my turnout c-track magnets by removing/shorting the small microswitches at least 15 years ago and never, never had any problems with them. I also use Traincontroller which has a, not foolproof, function detecting if the train goes the wrong way in a turnout. This works as long as the wrong track is not occupied, making it not foolproof but adds some security.
Just my experience, Peder
thanks 2 users liked this useful post by pederbc
This page was generated in 0.778 seconds.
