Offline QQQ1970
#1 Posted : 01 November 2019 00:20:43(UTC)
QQQ1970
Got the goliath crane. How much weight can it lift?
#2 Posted : 01 November 2019 02:50:59(UTC)
about as much as one David....
Offline QQQ1970
#3 Posted : 01 November 2019 03:12:47(UTC)
QQQ1970
Any ball park range say 500g or 20oz?
#4 Posted : 01 November 2019 13:08:59(UTC)
My Goliath can lift very easily one car (approx 100g) maybe two.
Two important limits:
- the tipping over when the arm is not raised enough (from 70° to 90° angle with horizontal)
- the sturdiness of the main pivot: because of the very short distance between the two bearing of the main rotating pivot, the rotating frame will bend a little.
Because of the number of cables to the hook and the motor/gearing, the pulling power is enough to lift a small loco (500g?)
On this old video, 5.10 minutes into it, see my Goliath lift a car. This is my former layoutBigGrin
Offline QQQ1970
#5 Posted : 01 November 2019 13:16:46(UTC)
QQQ1970
What do you use to link the wire (glue?) to the dowel to lift the car? You make it yourself?
#6 Posted : 01 November 2019 14:03:49(UTC)
I made a loop using a wire for sailboats with a square knot hidden under the car and holding it by the buffers
Offline QQQ1970
#7 Posted : 28 November 2019 19:24:22(UTC)
QQQ1970
I was able to lift Marklin 3064 V60 shunter with Ardelt crane, which weighs 204g.
Goliath crane lifting capacity (H0-scale)
by QQQ1970 01/11/2019 00:07:01(UTC)
This page was generated in 0.237 seconds.
