Offline 57vert
#1 Posted : 25 October 2019 01:48:52(UTC)
57vert
I am doing new construction presently. Some of my buildings are pre-wired with the little incandescent bulbs. I am worried about them burning out and having to access them when everything is permanently in place. Should I just bite the bullet and replace them all with LED lights that will “last forever”?
Offline Pfalzbahn
#2 Posted : 25 October 2019 04:31:30(UTC)
Pfalzbahn
Unfortunately yes, I would bite the bullet.
Pfalzbahn
thanks 2 users liked this useful post by Pfalzbahn
#3 Posted : 25 October 2019 14:50:15(UTC)
yes.
1. Incandescent ones also produce heat that can melt plastic.
2. Use this opportunity to place the lights where the ceilings would be - it produces realistic lights coming out the windows.
see https://cabin-layout.mix...ilding-plastic-kits.html for more lighting tips...
Offline Gregor
#4 Posted : 25 October 2019 17:01:03(UTC)
Gregor
I went for LED's as well.
I feed the 12V strips with approx 7.5V to reduce brighness to realistic level and to increase lifetime.
I do count on infinite life because if they break down I have to break open the roofs....
Gregor
thanks 3 users liked this useful post by Gregor
#5 Posted : 26 October 2019 15:31:58(UTC)
Both Faller and Brawa have newer LED units for buildings which work well. Viessmann have an over complicated system for lighting individual windows which also works well but has a lot of wiring depending on what you want to light in each building.
Offline PeFu
#6 Posted : 26 October 2019 16:35:43(UTC)
PeFu
I’m using these LED’s:
https://www.brawa.de/en/...der-with-led-warm-white/
LED’s tend to have a very narrow light angle. The Brawa type of LED’s have an add-on lense, that fix this, spreading the light as with traditional bulbs.
This page was generated in 0.493 seconds.
