Offline cajaeger
#1 Posted : 23 October 2019 11:55:28(UTC)
cajaeger
Luxembourg
after selling my Intellibox2, I‘m now a proud owner of a brandnew Central Station 3RollEyes
I have some understanding problems with the different driving steps. I know that mfx has 126 steps.
My questions:
- can I drive with CS3 an mfx-Decoder with the Motorola2-Format and 28 steps?
- as I have lot of locos with ESU Lokpilot4 (no mfx), can I drive with CS3 a Lokpilot4 with the Motorola2-Format and 28 steps?
thank you
Greetings from Luxembourg
Carlo
iTrain Pro 4.1.9, MacMini 2,4 GHz, High Sierra, 16GB RAM, 250GB SSD, Märklin CS3, IB old with Loconet-Ethernet GCA101, Märklin K (mfx/MM), Bemo H0m (MM), JMRI DecoderPro, Monitor 27" WQHD, Monitor 10“
#2 Posted : 23 October 2019 12:31:18(UTC)
No.
AFAIK the only Märklin controller ever that supports MM with 28 steps is the Central Station 60212.
The CS2 uses MM 27 for all MM decoders - sometimes this has disadvantages for decoders that do not support MM 27.
Not sure about the CS3, but would assume it also uses MM27 for all MM decoders.
Since ESU decoders do not support MM 27 AFAIK, you will only get 14 steps with those.
Better use DCC for all decoders that support DCC and MM.
#3 Posted : 24 October 2019 14:11:08(UTC)
If you set your locomotive (Märklin) which also support DCC protocol you can choice 28 or 126 speed steps.
This page was generated in 0.283 seconds.
