Offline morsing
#1 Posted : 01 October 2019 14:27:20(UTC)
morsing
I have attached a webcam, and the CS3 can see it's a C270, but just says Preview not Possible. Any ideas? I haven't found anything Googling.
Marklin C-track + CS3+
#2 Posted : 01 October 2019 18:57:55(UTC)
Offline morsing
#3 Posted : 01 October 2019 19:16:02(UTC)
morsing
Not really my kind of music but thanks?
Offline French_Fabrice
#4 Posted : 01 October 2019 19:38:13(UTC)
French_Fabrice
Just seen on a french forum Marklin has released a fix for CS3, which allows C270 (and maybe others) to run.
See http://www.3rails.fr/for...f=3&p=209375#p209375 and use a translator of your choice if you don't read French.
Fabrice
thanks 3 users liked this useful post by French_Fabrice
#5 Posted : 01 October 2019 21:54:50(UTC)
Fabrice
The gist of it (google translate) is:
Märklin has just provided a patch for running a WebCam with the CS3.
I just did the test and I confirm that now it works properly with a Logitech C270
To take advantage of this patch, you must force the update of the CS3 (Press simultaneously on the left rotary knob and the STOP key for ten seconds). The CS3 must of course be connected to the Internet
#6 Posted : 01 October 2019 22:35:16(UTC)
Okay I will ask the question.. Why on Earth would anyone want to connect a webcam to a CS3???? Confused
Offline Crazy Harry
#7 Posted : 01 October 2019 22:52:20(UTC)
Crazy Harry
To monitor hidden stations is one reason I can think of.
Harold.
Offline morsing
#8 Posted : 01 October 2019 22:56:17(UTC)
morsing
Fabrice
Fabrice, that was well found! Thanks, works now :-)
Offline morsing
#9 Posted : 01 October 2019 22:57:53(UTC)
morsing
Because it's fun?
#10 Posted : 01 October 2019 23:28:19(UTC)
Beyond me. Driving trains is fine and my steamers drivers have never heard of a web cam. Probably something that will upset a CS3.
#11 Posted : 02 October 2019 06:16:07(UTC)
Märklin in YouTube did present video how to use webcam with mpeg4. I did follow exactly Youtube video referens.
#12 Posted : 02 October 2019 09:22:47(UTC)
Sorry i missed one more symbol...Blushing
www.youtube.com/watch?v=gEoxn84rLuo
Offline morsing
#13 Posted : 02 October 2019 09:33:31(UTC)
morsing
Thanks, I had already watched this but it's not a very helpful video when things don't work.
#14 Posted : 02 October 2019 10:38:50(UTC)
I still don't get why one would plug it into the cs3. Why not plug it direct into the PC and save the workload of streaming video by the cs3? Doesn't make sense to me.
Personally I would use a raspberry Pi as a web cam server instead, and have it run direct to a screen.
Offline morsing
#15 Posted : 02 October 2019 11:06:14(UTC)
morsing
More and more cabling. The cables that go to my garage are 20m long and requires crawling around the loft. And please don't say "wifi", wifi is the d3vil.
#16 Posted : 02 October 2019 11:26:16(UTC)
Alan a raspberry pie sounds good. Do we heat it or have it cold. Seriously what is wrong with the underbed decoder.
I know there has in the past been talk about turnout motors but I would suggest to buy one along with a decoder and give it a go.
#17 Posted : 02 October 2019 11:43:45(UTC)
Hang on, we are talking about web cams here, not turnout decoders ... Confused
#18 Posted : 02 October 2019 11:46:29(UTC)
So, the camera is plugged into the cs3, where is the picture displayed? The impression I have from the video is that it is displayed on a PC.
It would be possible to do the same with an RPi, hooked to the same network, so offloading the video streaming from the cs3.
I still can't see any advantage to loading down the cs3 with handling the video streaming.
Offline morsing
#19 Posted : 02 October 2019 11:52:14(UTC)
morsing
Would still require a cable to the garage and I'm not installing crap switches on my network nor am I spending hundreds on a switch just for the garage.
I think this debate has gone off track a bit. I asked why the CS3 could not see the webcam picture, which Fabrice solved, I did not ask about networking or fruit pies...
#20 Posted : 02 October 2019 12:47:19(UTC)
Yeah, but from the video it seems the cs3 does not then display the picture, so I'm wondering how you are going to do that.
Offline morsing
#21 Posted : 02 October 2019 13:05:46(UTC)
morsing
The CS3 has a webserver and the video stream is available via that.
#22 Posted : 02 October 2019 14:20:46(UTC)
Right, so you have a cable to the garage, and could put an ethernet switch there if needed.
Offline morsing
#23 Posted : 02 October 2019 15:07:36(UTC)
morsing
I could but:
[...] I'm not installing crap switches on my network nor am I spending hundreds on a switch just for the garage.
I can't believe a webcam would saturate a piece of modern hardware. If it does, I won't use it, it's not that important to me.
#24 Posted : 02 October 2019 17:32:39(UTC)
Apologies Alan. I think the same member has a thread running about turnout switches.
Will go and have a lie down.
This page was generated in 0.784 seconds.
