Offline marcelltrain
#1 Posted : 28 September 2019 07:42:05(UTC)
marcelltrain
With the digital system, I understand that it is possible to know how long a locomotive has been running, someone could tell me how I can know how to do that. This information is very useful to know when the locomotive should be serviced.
Offline French_Fabrice
#2 Posted : 28 September 2019 11:02:08(UTC)
French_Fabrice
I've never heard this kind of feature is embedded in Marklin CS2; For the CS3, I don't know...
However, I know external software like RocRail are able to manage it. For example, see https://wiki.rocrail.net/doku.php?id=loc-gen-en , field "Run Time"
I suppose other software of the same class (TrainControler, iTrain, and others) have the same feature.
Other members may provide more accurate answer.
fabrice
Offline blid
#3 Posted : 28 September 2019 11:24:19(UTC)
blid
MTH ProtoSound decoders accumulate time and distance if you have one of those.
thanks 1 user liked this useful post by blid
#4 Posted : 28 September 2019 15:22:02(UTC)
marcelltrain
As the owner of a dealer Marklin told me, they can see how much time your locomotive has run, so, That is because I think that it is possible somebody know how can do it
Offline PMPeter
#5 Posted : 28 September 2019 16:16:24(UTC)
PMPeter
I have a CS2 and have never heard about or found this feature. However, as Fabrice has pointed out in his reply, I get this information through Rocrail.
Offline Gregor
#6 Posted : 29 September 2019 13:53:01(UTC)
Gregor
I wrote my software myself and included this feature:
It gives quite some insight.
Some decoders capture this info as well, for instance ESU. You can access the info through Lokprogrammer.
But I do not know what is the definition of active: Actual running or only enabled.
Gregor
thanks 4 users liked this useful post by Gregor
OTTBERGEN MODEL RAILWAY EXHIBITION - 51 Minutes running time (H0-scale)
by ShannonN 19/05/2019 05:23:41(UTC)
Could limited running time, create a problem? (General MRR)
by ParisTsirchoglou 07/10/2015 09:02:09(UTC)
This page was generated in 0.460 seconds.
