Offline Peter Pop
#1 Posted : 21 August 2019 23:19:04(UTC)
Peter Pop
Bought the yellow habbniillnes sets . All cars of
both sets derail from straight to curve track and visa versus even using the r4 and r5 radii. The wheel carriage gets stuck on the under siding of the car. Adjusted the position of the wheel carriage , no change. Any suggestions ?
#2 Posted : 22 August 2019 00:02:31(UTC)
I have the 48063 set on order. I'll check it when it arrives.
Offline mrmarklin
#3 Posted : 22 August 2019 01:04:42(UTC)
mrmarklin
Push in the buffers.Crying
#4 Posted : 22 August 2019 04:01:45(UTC)
If you are talking about the 48059/48062 Wascosa SBB Swiss Post cars, you need to inspect the bogies of these models. When I received the first set, I noticed that one of the bogies on the German language car had a different bogie than on the other end and on the other cars. I contacted my dealer, who informed me that Maerklin was replacing those bogies, but was not recalling the sets.
It took a while, but the dealer received the part and I replaced it and the cars are now operating fine.
See: https://www.marklin-user...erklin-car--bogie--48059
You should not have any spacing issues on R4 or R5. Pushing the buffers in should only be required when using R1 and possibly R2.
Check to ensure that the couplers are not hitting the bottom of the buffers and that the coupling mechanism slides freely left to right.
Offline michelvr
#5 Posted : 23 August 2019 15:31:15(UTC)
michelvr
Hello Peter,
Re: MARKLIN 48062 - 3 Type Habbiillnss High-Capacity Sliding Wall Boxcar Set
Just to confirm your observation you are correct in stating that the wheel bogie gets stuck on the underbody frame of the freight car causing it to derail. I also had the same issues and just last Monday August 19 I returned the set to my dealer. I bought it early spring and only took it out for a spin last week when I noticed the issues of them derailing on curves.
It's very unfortunate as the set was quite beautiful and looked super on my layout.
I'm sorry to see it go as I run my trains and this set did not play by the rules!
Looking at the picture you will notice that the black plastic underbody frame is not straight it's actually bowed. Besides causing derailment on the curves you will also notice that the buffers and couplers are also angled downwards and they misalign when you try to couple them. This is all due to the bowed frame. Marklin needs to make a gusset to reinforce the black plastic underbody frame. This is so that it will not bow and be straight so that this freight cars will be in alignment with the others.
Offline michelvr
#6 Posted : 23 August 2019 16:22:43(UTC)
michelvr
Please note for discussion clarity the video is for explaining the issue with the MARKLIN 48062 - 3 Type Habbiillnss High-Capacity Sliding Wall Boxcar Set derailing. No harm intended.
thanks 4 users liked this useful post by michelvr
Offline Thewolf
#7 Posted : 23 August 2019 16:38:18(UTC)
Thewolf
Hi Michel Cool
If my memories are good, I believe that a boogie positioning scheme is attached to the product, precisely in order to avoid these kinds of problems.
I'm talking about memory.
Thewolf
Offline Peter Pop
#8 Posted : 23 August 2019 22:00:12(UTC)
Peter Pop
Thanks exactly the same with my set. I did adjust the position of the bogy without improvement. When I am back to my layout I will check how the wheels are secured to the wheel carriage. Will post follow up
thanks 1 user liked this useful post by Peter Pop
Offline michelvr
#9 Posted : 24 August 2019 03:20:12(UTC)
michelvr
Hi Michel Cool
Thewolf
Hello Thewolf,
I'm not sure what you mean by a boogie positioning scheme is attached to the product?
What's actually wrong is that the frame of this particular freight car is bowed/warped. Which in turn is preventing the pivotal movement of the bogie causing the wheels to derail when it runs into or onto a curve. Please look at the video and you'll see what I mean.
Have a great evening!
#10 Posted : 24 August 2019 14:12:16(UTC)
Would it be possible to improve the clearance between the bogie and the frame so as to prevent this? I am thinking that a thin washer on the pivot might do the job, or maybe a small amount of filing where the contact occurs?
I bought a couple of Hobby fridge vans a few years ago which would not run freely. When I looked carefully I noticed that the wheel flanges were rubbing on the bottom of the underframe. I took a small file and filed a groove in the underframe to allow clearance for the wheel flange, and this allowed the wagon to roll freely. This seems to have been a one-off problem that year because more recent versions of that van have not had the problem, and all my older ones are perfect too.
I know it is irritating to have to work on a brand new product, but sometimes a few minutes work solves a problem which otherwise would mean sending it back and not having it at all!
Offline michelvr
#11 Posted : 24 August 2019 15:10:47(UTC)
michelvr
Hello Ray Happy Saturday,
The repair guy in me was going to modify the cars but at $169.99 for the set, nope not going to happen! I for one love to tinker and fix things but not this time, no this is not acceptable!
By the way this was not a one off as Mike my dealer from West End Trains tried with a multitude of different cars from the MARKLIN 48062 - 3 Type Habbiillnss High-Capacity Sliding Wall Boxcar Set all exhibiting the same problem.
Now that Mike knows the issue he will pass it on to Märklin. With a simple mould modification the problem can be solved for all the cars that will be produced in the future. When done I’ll the on the waiting list.
For now the best course of action is to return the cars to Märklin. When people like us say Märklin we speak about quality products which is what Märklin is famous for! Anything less is not acceptable, ja, das ist wahr, yes that is true!!
Offline Thewolf
#12 Posted : 24 August 2019 15:58:35(UTC)
Thewolf
Hi Michel
I forgot to mention that I have this set and it's at Mike's, because I have the same problem.
I haven't heard from Mike: I know he has a lot of repairs to do.
But if I understand correctly, it seems irreparable to Mike.
But if Marklin has to make a new mold, Marklin has to reimburse us I think, since we don't know how to do anything with this set.
Have a nice day
Thewolf
Offline Thewolf
#13 Posted : 24 August 2019 19:28:33(UTC)
Thewolf
This is what I was talking about
48062 Instruction.pdf (805kb) downloaded 122 time(s).
According to Mike, this should work.
Here his answer that I received 15 minutes ago:
''. I did this today to 48062 and I can run it on my Heidelberg at almost full speed on the R1 curves and through standard turnouts that have a S shape.
Mike Sorge
Westend Trains Inc. www.westendtrains.com
17 Arnold St.
Etobicoke, ON M8Z 5A5
T: 416.251.6124
F: 416.251.1637''
Thewolf
Offline Peter Pop
#14 Posted : 24 August 2019 21:22:24(UTC)
Peter Pop
Did change to number 3 position ie closer to the center of the car , still derailed. Buffers were already pushed in by factory
Offline Thewolf
#15 Posted : 24 August 2019 23:07:43(UTC)
Thewolf
Hi PeterCool
Okay, I understand.
But there's something I don't understand in this thread.
You seem to be saying that there is nothing to do to avoid derailments, just as Michel seems to be saying too.
Michel and I have the same dealer, Mike.
Mike writes to me that after adjusting the boogies, it was working on his Heidelberg layout. I know the Heidelberg layout: I owned it for a few years.
And believe me when anything on Heidelberg, everything works on any layout
There's obviously something wrong here.
As for me, I'll wait for the set to come back but if Mike tells me it works, it works.
Thewolf
Offline michelvr
#16 Posted : 24 August 2019 23:49:09(UTC)
michelvr
Hello Serge,
Mike wrote me an email today also saying that they work fine.
BUT I like Peter tried different positions and that I know is not the problem.
The black underbody frame is warped, bent or bowed, that's the problem.
I just sent Mike a very detailed hypothesis of my findings.
I'll post a part of it here which is more or less what I wrote in an earlier post above.
Now let’s look at the picture below.
If you look at the picture you will notice that the right car's black underbody frame is not in a straight line. Visually you can see that and to verify what I was seeing I used a height gauge. I measured the length of the underside of the black underbody frame and the heights were off at both ends. In other words, the frame is bent on both ends! Again now looking at the picture you will notice that the buffers are slightly on a down angle which actually is all caused by the black underbody frame. With this cascading effect the coupler position is now out of gauge. I used a coupler height gauge from Kadee to measure that. The frame's warp or slight bow downwards accentuates the coupler's assembly height position and causes the coupler to be too low to couple to the next car or engine in my case.
Offline michelvr
#17 Posted : 24 August 2019 23:56:03(UTC)
michelvr
Anyway;
This hobby is about having fun running your trains but hey you gotta laugh and cry at the same time when this happens!
Have a great Saturday evening!
Michel
Offline Thewolf
#18 Posted : 25 August 2019 00:13:34(UTC)
Thewolf
Hello Serge,
Well, I understand better.
I hadn't looked at the first picture very seriously... and indeed there is something fishy on the right car.
Keep us informed of your conversation with Mike.
As for me,as it is not certain that my set has the same defect as yours, I will therefore check thoroughly when the set is back.
An idea like this : and if we would cut or remove the buffers
What do you think about this ?
Serge
Offline Thewolf
#19 Posted : 25 August 2019 00:20:00(UTC)
Thewolf
Anyway;
Michel
Michel,
You are rightCool
For the moment, I'm only half fun: too many connection problems, design problems with the layout and configuration of Itrain.
This project is provisional: it allows me to see the mistakes I make and I take note for next year and the final layout.
I will certainly do it differently. The real fun will be for that moment there
Serge
thanks 2 users liked this useful post by Thewolf
Offline Peter Pop
#20 Posted : 03 September 2019 19:15:28(UTC)
Peter Pop
Did just now check the bogie and they are the correct Märklin ones. Tested all the cars and they all derail from straight to R3 radius C track and visa versa. Even with R4 there is the same problem. It gets stuck on the bottom of the car. I have older similar cars with imprinted “ made in west Germany “ which run just perfectly. Changed the position of the boogie which just made it worse. I quess they will go back in the box and will be returned
#21 Posted : 05 September 2019 07:48:33(UTC)
Hello All,
I received the 48059 Set last year. I did not test it because I noted that one of the bogies did not match the others. I set the models aside and asked my dealer (Eurorailhobbies) to contact Maerklin and obtain the correct part.
A few months ago, I received the 48062 set, which had all the right bogie parts and finally received the replacement bogie, so that my 48059 now has matching bogies.
Based on this topic, I decided to examine them in a little more detail…
Based on inspection, I cannot see any signs of warping. What I did note is that on all three cars of the original 48059 set, there appears to be blockage when the bogie pivots. This could ostensibly cause the car to derail when the car enters a curve or crosses a switch track. This is not the best week, as I don't have much free time and many dealers are in Germany for the IMA.
I will drop my dealer (Mr. Menzel) a quick email regarding this discovery and hopefully he can address it with Maerklin.
I will compare the cars to older similar cars in my collection (SNCB B Cargo). to see if those bogies have a similar issue.
#22 Posted : 05 September 2019 13:19:40(UTC)
I just realised that I have this set (i.e. 48059).. It works fine on R1 and R2 M-track.. In a couple of weeks when the train room air-conditioner is replaced and the bridge is returned to its proper position, I will do a video..
#23 Posted : 05 September 2019 13:36:39(UTC)
Hi all, good (and scary) to know. I bought a 48059 at Eurowest last month, and haven't tested it yet. And of course I put the set in storage for the interim as well since I'm finishing the basement for suture layout activity :)
#24 Posted : 05 September 2019 19:09:31(UTC)
Hello All,
I had a little time today, so I set up a quick test track using some straight track and a quarter curve using C Track (R4).
On the first test, the second and third car (48059) derailed as each car entered the curve. The first car remained on the track.
I removed and reversed the direction of the second car. On the subsequent test, only the third car derailed.
I then reversed the direction of the last car, but it still derailed.
I then reversed the direction of the first car and on the next test, all three cars derailed.
The problem is NOT related to the buffers. The bogie is not freely pivoting and this results in the wheels not being able to remain on the rails.
It may be possible to install some kind of spacer which would provide a little gap between the bogie and the undercarriage.
I will have to remove one of the bogies and see what it looks like underneath and try to see what is interfering with the rotation.
I will also try to dig out the older SNCB car to see how that car performs and test the other set (48062) as well.
#25 Posted : 06 September 2019 06:45:03(UTC)
Hello All,
sometimes you have to change the coupling so long the cars have coupling shafts, we're changing most of our Roco/Märklin carriages with 40375 couplings, they couple into a double hook by both couplings therefore a.) the wagons will not uncouple b.) they seem to be flat enough not to interfere with the undercarriage.
#26 Posted : 06 September 2019 06:48:43(UTC)
Unfortunately in this case, it has NOTHING to do with the couplings. It is the bogies themselves that are blocked by something on the undercarriage and cannot freely pivot, causing the car to leave the tracks...
The cars derail, even if they are pushed into the curve on their own.
#27 Posted : 06 September 2019 10:25:03(UTC)
Hi Mike,
Are the cars heavy enough? Does adding a bit of weight help at all?
Either way it does seem to me that the problem stems from the bogie's inability to rotate freely. I'm still waiting for the 48063 set I ordered to arrive so I'm naturally concerned that this might be a problem with this set too.
Offline michelvr
#28 Posted : 06 September 2019 15:17:25(UTC)
michelvr
Fellow Märklin enthusiasts,
Imagine buying a boat that would not float or an aeroplane that would not fly. Now having bought a freight car set that would not run on the rails will not do so in all fairness my solution is the easiest way to fix the problem.
I returned them to my dealer!BigGrin
Regards, Michel
#29 Posted : 06 September 2019 15:27:09(UTC)
Regards, Michel
Simple solution of course, except for two things.
Firstly it means you have to post the parcel back to your dealer, assuming he will give you a refund (unless your dealer is close to you and you can visit personally, which is not very common in today's world!) This might or might not incur extra postage which might not be recoverable.
Secondly, and more importantly for me, you will end up back at square one with no wagons to show for your efforts!
I am a firm believer in the option to attempt a "fix", as long as this is possible, easy, and cheap. As I wrote in an earlier post, I have used a small file to fix similar issues in the past.
#30 Posted : 06 September 2019 16:08:19(UTC)
I have now tested my 48062 and can attest that this set also seems to be affected. I still have to go through my collection to find and test the 48032 SNCB Cargo Sliding Wall Car to see if it has the same design/problem.
Regards, Michel
Ray,
would you buy a new car if the first thing you had to do when leaving the dealership was change the spark plugs, suspension spring and headlights?
If I buy a SBB Lok and I have to straighten out the diagonal railing on the lok face, that is one thing. If the damned thing won't run properly, why should I have to take it apart to figure out what the problem is when I paid for a new and operating model?
There already is a silent recall on this model. In my case, Maerklin replaced a bogie that was not the same as the other 5 on my 48059 set. It may be that ALL bogies need to be replaced or will be replaced if requested... We need MORE details from dealers and from the factory on this one.
Once again, here is a link to my original topic regarding this model:
Offline michelvr
#31 Posted : 06 September 2019 17:29:50(UTC)
michelvr
Regards, Michel
Hello Ray,
Yes, I also feel the pain when it comes to returning items, like you I live in a remote area to be a model railroading enthusiast. But I’m in a small way luckier than you as I have a dealer in Toronto. When it come to wanting a certain Märklin item I have to order it and wait, them take a drive. The drive is ninety minutes on a good day but sometimes over two hours when the TORONTO traffic is bad!!!!! That's one way.
But unlike you I do not live on a rock which is in a hard place when you always have to order items from the mainland, so I get your point to do the repair. We are of the same mindset where we have the ability to modify and correct deficiencies on our model trains but at the price I paid close to $200.00 with taxes Canadian, NO WAY will I accept this, it's going back!!
Remember this stuff is expensive at these prices it should run like a Swiss watch!Laugh
Offline Thewolf
#32 Posted : 06 September 2019 17:41:54(UTC)
Thewolf
I totally agree and that's what I wanted to describe in my post'' the quality control at Marklin''' or something like that
Thewolf
#33 Posted : 07 September 2019 11:11:04(UTC)
As promised, here is a video of the 48059 set going over a Marklin 5120 Industrial curve (R0) - forwards and backwards. All of the bogies are the same and there is no obvious "sticking" when I turn the bogies. The little Lilipiut is running at 50% speed, which is a tad fast for the curve, but there is no derailment on the curve.
While the video shows one forward and reverse run through the curve, I tested this over a period of two hours using different speeds and sequence of the wagons. So, if it works on R0, then it should work on R4 and R5.. Smile
Offline michelvr
#34 Posted : 07 September 2019 15:40:22(UTC)
michelvr
Hello xxup,
Not to burst any bubbles but we had done the same on the store layout which was on Märklin C track R1 oval. The store owner Mike and I looked on in amazement as it ran flawlessly round and round. We were running the set slow, faster and faster for a good 5- 10 minutes with the set running perfectly!
Then when I brought it home...............
As mentioned I loved ❤️ their set and was sad 😔 to see it returned.
#35 Posted : 07 September 2019 18:24:31(UTC)
This is exactly the issue that I observed when I tested my 48059 and 48062 sets.
I tested them on C-Track and manually without track and observed blockage when pivoting. It did not happen every time, but with the right position of the bogie, something seems to interfere with the free motion. The bogies can be removed by pressure on the clip using pliers. I have not had the time to inspect the undercarriage to see what is causing the problem. I remember a few models where the coupling shaft was causing a similar problem, but in this case, this does not seem to be a factor. It could be the spring for the coupling mechanism or some obstruction or detail on the car underside, possibly the adjustable seat for the bogie pin... Has anybody repositioned the bogie pin to tighter radii. If Adrian changed the position, it might have solved the problem if it moved or removed the point of contact.
Stay tuned
#36 Posted : 07 September 2019 23:33:48(UTC)
Conclusion - replace the c-track with m-track.. LOL
Offline fusionfaded
#37 Posted : 07 September 2019 23:55:57(UTC)
fusionfaded
I had the exactly same issue with my Habbiillnss cars too. Even a single car will derail on a curvy track as the bogies seem to be unable to turn free randomly.
The Store sent them back to Göppingen, but after receiving them back 6 Months later they were as bad as before. Confused
My impression was that the bogies simply get stuck on the undercarriage of the car if not absolutely perfectly level. The top of the bogies resemble I-Beams and are perfect for getting stuck.
I shaved of those plastic "lips" off at a 45 degree angle using a knive and some sandpaper. I haven't had the chance to test them on "real" track, but they do no longer derail on my test setup (a bunch of "S-Curves).
Offline Thewolf
#38 Posted : 08 September 2019 01:21:43(UTC)
Thewolf
What pisses me off in this comment is the fact that the item is back to Marklin. It stays there for 6 months and it turns out that nothing has been done. Marklin seems doesn't care at all his clientCursing
Damn it!!!
Thewolf
Offline mmervine
#39 Posted : 08 September 2019 03:03:46(UTC)
mmervine
I have a set of these cars (48059) and tonight I took a look at mine. I do not have the issue with the bowed underframe, but they did sometimes derail on R1 curves. I removed the bogies and noticed that there was some mold flash and uneven surfaces on the top. I did two things to my cars:
1. I filed the top of the bogies to smooth them out
2. I added half an ounce of weight to each car
They now seem to run much better!
thanks 2 users liked this useful post by mmervine
#40 Posted : 08 September 2019 04:37:11(UTC)
... If Adrian changed the position, it might have solved the problem if it moved or removed the point of contact.
I did.. There are instructions on how to set up these cars for small radius curves.. Personally, I am surprised at how well they go around the R0 curve.. I know that on R1 and R2 they ran without problems a year ago, when I first got them..
#41 Posted : 08 September 2019 11:25:49(UTC)
This is exactly what I have been suggesting in an earlier post or two! ThumpUp
When I receive mine I'll check to see if they display the problem and if they do I'll try just this kind of solution. Anything is better than having to send them back!
#42 Posted : 08 September 2019 23:27:11(UTC)
thanks 4 users liked this useful post by Purellum
#43 Posted : 11 April 2020 22:37:18(UTC)
Hi everyone, apologies for reviving an old thread, but hopefully I can provide some additional inputs.
My 48062 arrived from Germany today, and it reminded me to also pull out my 48059 for testing. The bogies on all 6 cars certainly felt terrible! My second immediate thought was the cars needing weight.
After torture testing as a set on my figure 8 - both forwards and backwards - I have one "bad" car. I was surprised the rest even worked. But anyhow, I filed the top of the bogie and as I started doing so I realized they are made that way for the opposite reason- to push the trucks toward the track and away from the body (vs towards the chassis, where they will hang up)
The fix took a little thought, but was quite simple- a thin brass washer between car body and bogie, or two on the side I filed by mistake... The car run flawlessly now.
be careful not to use too thin of a washer or the bogies won't rotate/turn freely enough.
Edited by user 20 April 2020 01:50:58(UTC)  | Reason: Not specified
Guest (6)
This page was generated in 1.346 seconds.
