6 Pages«<23456>
Offline 1borna
#151 Posted : 22 June 2019 17:51:55(UTC)
1borna
Croatia
Hostel in the wagon is at the Main Station, the layout has 2 tram stations and 200 meters of foot.
It can be just a walk away, it takes about 20 minutes to walk.
On the other side there are 10 minutes to the Croatian Railway Museum.
Display
Museum
Maybe our club can be visited 300 meters away from Backo mini epress
link
thanks 8 users liked this useful post by 1borna
Offline 1borna
#152 Posted : 12 July 2019 20:59:44(UTC)
1borna
Croatia
Each house gets the light, the larger it has several
In addition, they also get a new color to avoid plastic shine and various details
UserPostedImageUserPostedImageUserPostedImage
Turning on the light gradually, from dusk to full night
thanks 6 users liked this useful post by 1borna
Offline 1borna
#153 Posted : 25 July 2019 21:24:11(UTC)
1borna
Croatia
In reality, the light was so strong, the camera itself extended the exposure and it turned out so
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
Offline 1borna
#154 Posted : 08 August 2019 18:11:35(UTC)
1borna
Croatia
Trains run from all countries to the layout
It is more interesting to visitors than to see trains from only one country
Trains from all epochs also run
The curious always explain from what period a train was traveling and in which country it was traveling
thanks 9 users liked this useful post by 1borna
#155 Posted : 08 August 2019 21:17:22(UTC)
Neat.
Can you or someone explain what is going on with this cantenary and mast? Am I seeing that correctly, that the wire makes a jump to the side at the mast arm?
Offline 1borna
#156 Posted : 08 August 2019 21:23:33(UTC)
1borna
Croatia
Thanks for the good remark!
I'll let the guys fix it if it's not already?
When mounting figures or other work, it is likely that someone stuck to the wire and moved it.
thanks 2 users liked this useful post by 1borna
Offline 1borna
#157 Posted : 18 August 2019 21:19:20(UTC)
1borna
Croatia
This part is slowly progressing and looking better
I always look at what is being done in the workshop
thanks 7 users liked this useful post by 1borna
Offline 1borna
#158 Posted : 06 September 2019 21:37:49(UTC)
1borna
Croatia
This hill was, until recently, empty and not interesting
Creating a pedestrian walkway to the ski lift became interesting
There are some beautiful pictures from earlier up
Offline 1borna
#159 Posted : 19 September 2019 19:46:19(UTC)
1borna
Croatia
At this station is working on the details
A small facility was built nearby
Offline 1borna
#160 Posted : 11 October 2019 21:35:17(UTC)
1borna
Croatia
And in a little space a good scene can be made
On one hill is a hangout for dragons
Some are not very nimble
A little look from the bridge
Below the bridges is a staged train jump accident
Offline 1borna
#161 Posted : 01 November 2019 21:43:53(UTC)
1borna
Croatia
UserPostedImageThe last part of the workshops is intended for rougher jobs
For precision jobs, you must have the right tool
UserPostedImageA larger box was created as a carrier for battery train controllers
Young children often do not want to return controllers when their ride is over, so they cannot take it this way
Online kiwiAlan
#162 Posted : 02 November 2019 14:13:40(UTC)
I take it the counter display counts down to the end of their turn BigGrin
Offline 1borna
#163 Posted : 09 November 2019 20:25:53(UTC)
1borna
Croatia
The construction of another major crossroads has begun
Numerous stop points, space for stop magnets and various sensors need to be carved
When the guide wire is inserted into the notched grooves, everything is swept and subsequently sanded
Only then on the down side does the extensive job of setting up a high-frequency field to power the vehicle follow
Offline 1borna
#164 Posted : 18 November 2019 21:29:34(UTC)
1borna
Croatia
Now that looks neater
That will come here
In the middle is a drive to move pedestrians on the surface
A lot of sources for HF power supply have been made
One part of the previously made route is under test
Frequency, voltage and current field strength are measured
Each of the numerous sections of the tracks was photographed and all relevant information was recorded
Offline 1borna
#165 Posted : 03 December 2019 21:14:49(UTC)
1borna
Croatia
Below the layout are a number of HF road power supplies
New sections of roads are laid will be painted after rehearsals
There were corrections on the old part
One section has a groove for magnets ...
... powered by a chain
A few days ago, the entire space was decorated for Advent
thanks 4 users liked this useful post by 1borna
Offline 1borna
#166 Posted : 20 December 2019 21:34:46(UTC)
1borna
Croatia
And the store is a lot nicer these days
This part of the layout was able to be completed before Advent
Offline 1borna
#167 Posted : 02 January 2020 20:24:25(UTC)
1borna
Croatia
Even the smallest part can be beautifully decorated
The city got the final schedule
There are a lot of visits these days
Offline 1borna
#168 Posted : 12 January 2020 20:11:18(UTC)
1borna
Croatia
One CNC machine was purchased
It is quickly complex and tried and tested
A little later it was completed
And there is always work for a lathe
The workshop becomes too small
Especially when doing big projects
(Layout of new road rotor in Zagreb is at scale 1: 220)
thanks 5 users liked this useful post by 1borna
Offline 1borna
#169 Posted : 25 January 2020 21:06:43(UTC)
1borna
Croatia
The Advent crowds are gone, so it's normal now. Part of the team is with visitors and others are completing some projects or doing new ones
Who would say that there is so much under the road?
Everything is made very neat and precisely connected
The new town square has been illuminated
Online kiwiAlan
#170 Posted : 25 January 2020 23:39:27(UTC)
Only way to have it to minimise any problems at a later date ThumpUp ThumpUp ThumpUp
Offline 1borna
#171 Posted : 06 February 2020 21:15:21(UTC)
1borna
Croatia
I will continue to show the design of the rotor
Numerous trams and buses were built
They needed to paint them and bring them lighting
Other road vehicles are from the standard Z program
Brass etching made the supports for traffic lights
Everything was done according to the design of the situation on the right rotor
This was followed by a demanding signaling connection (rotor inverted)
Offline 1borna
#172 Posted : 10 February 2020 21:06:36(UTC)
1borna
Croatia
The grass began to be sown on the ground
There will be more pedestrian walkways in the center
In the middle is a tram line
This seems more serious now
The tram line is made of colored wire, glued into the slots
Offline dominator
#173 Posted : 10 February 2020 21:18:17(UTC)
dominator
This seems more serious now.
Your not kidding. Amazing stuff. Keep up the good work.
Dereck
Northland. NZ
Offline 1borna
#174 Posted : 13 February 2020 20:33:45(UTC)
1borna
Croatia
Thank you!
The tramway is made of black painted wire that is slightly buried in the base and glued
Offline 1borna
#175 Posted : 16 February 2020 20:34:48(UTC)
1borna
Croatia
Offline 1borna
#176 Posted : 22 February 2020 20:19:30(UTC)
1borna
Croatia
Installation in city government
In the dark it looks even better!
Here it is in reality
Offline 1borna
#177 Posted : 02 March 2020 20:00:55(UTC)
1borna
Croatia
Back on the rail, the elevator works flawlessly. He rises and lowers a hundred times a day and switches trains
Road vehicles are still running, pay attention to the garage
And the ramps in this parking lot will work
A few more details emerged here
Offline 1borna
#178 Posted : 19 March 2020 20:57:25(UTC)
1borna
Croatia
Driving on the roads is still in trial phase
This is an overview of the roads to our left
and on the right
There may be a jolt in the parking lot
There's news here
thanks 3 users liked this useful post by 1borna
Offline 1borna
#179 Posted : 24 March 2020 21:33:59(UTC)
1borna
Croatia
There are 10 days as the virus layout is closed to visitors, work on it was suspended last Friday. After the earthquake there was no damage, the entire space was generally renovated before the construction began.
I still have a lot of photos so I will continue the picture book a little less often and with less pictures.
Offline 1borna
#180 Posted : 07 April 2020 20:35:08(UTC)
1borna
Croatia
In addition to the school was formed and sports hall
There is also a statue of an athlete in front
There is one parking lot nearby
and one nice old building
Offline 1borna
#181 Posted : 22 April 2020 21:39:26(UTC)
1borna
Croatia
There are many small details on the layout that can only be seen by careful observation
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
Offline 1borna
#182 Posted : 10 May 2020 22:00:04(UTC)
1borna
Croatia
2 more road rotors will be made, this time at a scale of 1: 500
Traffic light and road sign carriers are made of etching
Vehicles were made with 3D printing
Edited by user 30 May 2020 21:16:07(UTC)  | Reason: Not specified
Offline 1borna
#183 Posted : 30 May 2020 21:27:21(UTC)
1borna
Croatia
Relief is being done
And here they are ready
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
I recently took a walk on that rotor
The greenery and flowers have not been arranged yet
Offline 1borna
#184 Posted : 17 June 2020 21:18:28(UTC)
1borna
Croatia
About a month ago we were open for visits again
Some could hardly wait for that
Earlier, this intersection was removed for repairs
Some of the numerous routes were too close to each other, so it was possible to make a wrong turn
More vehicles had to be tested on various routes
Below the intersection is a chain that moves pedestrians on the surface with magnets, it needed to be slightly tightened and lubricated
(older video)
Offline 1borna
#185 Posted : 04 July 2020 20:58:26(UTC)
1borna
Croatia
One rail cleaning car driving on the road?
And that is possible when the Backo team processes it, also has wireless power
There are about 300 meters of roads on the layout, a good part of which is in tunnels and inaccessible, so this way of cleaning dust is welcome!
One day when everything is in use there will be over 100 different vehicles on the roads
All have wireless power supply, decoders and are controlled via infrared rays
This does not drive but moves by hand and serves to measure the frequency and strength of the current field on the road
Locomotives run on the layout for several hours every day, so now there are close to 200 because there are always at least 10 of them in service.
Some locomotives also need to change the rotor because the brushes "eat" the collector after several changes.
Newer electric motors are not repaired but replaced
Offline Gregor
#186 Posted : 05 July 2020 09:12:17(UTC)
Gregor
Impressive!
This modified Lux cleaning car is simply brilliant ThumpUp
Gregor
thanks 1 user liked this useful post by Gregor
Offline 1borna
#187 Posted : 24 July 2020 20:32:31(UTC)
1borna
Croatia
Thank you!
There are new details on the layout
Amusement park with narrow gauge railway
I’m going to have to record one video because it’s running!
One bar was opened below the station
The facade is being renovated
There are more works
A waste space has been arranged
Offline 1borna
#188 Posted : 09 August 2020 21:06:06(UTC)
1borna
Croatia
A layout of any size without small details would look unfinished
Figures and vehicles give life
This certainly includes various advertisements
We can work and improve all these small details over the years
Thanks to Preiser for providing us with countless figurines for all needs
Offline 1borna
#189 Posted : 19 August 2020 21:41:28(UTC)
1borna
Croatia
Offline 1borna
#190 Posted : 05 September 2020 20:34:50(UTC)
1borna
Croatia
The small restaurant has good food so it is always full
UserPostedImage[/img]
The handball players started the match
UserPostedImageUserPostedImage[/img]
Fans who did not stop at the hall gathered in one pub
I shot some scenes from a lower position
Offline 1borna
#191 Posted : 19 September 2020 20:03:37(UTC)
1borna
Croatia
I haven't presented compositions for a long time
Upstairs there are always more on hold
thanks 1 user liked this useful post by 1borna
Offline 1borna
#192 Posted : 04 October 2020 20:16:53(UTC)
1borna
Croatia
#193 Posted : 24 October 2020 06:44:30(UTC)
I'm completely gobsmacked, the technical side is just outstanding, the work that has gone into is amazing, the only thing I'm not keen on is whereas the tracks are stacked up on different levels but suppose it takes you from some prototypical examples to a world of dreams. the track lift is another outstanding feature.
Offline 1borna
#194 Posted : 26 October 2020 21:15:38(UTC)
1borna
Croatia
Thank you, the layout does not have a specific template, but it is inspired by the Swiss Railways, where there are many tunnels and bridges and high mountains. In addition the layout is made for visitors who like to see various attractions and lots of trains on the move.
Recently, a small amusement park was removed from the layout for minor landscaping
I took the opportunity to film it from all sides
The scale of the garden rail is approximately 1: 500
The drive from above looks like this
Offline 1borna
#195 Posted : 24 November 2020 20:44:47(UTC)
1borna
Croatia
https://lh3.googleusercontent.co...w1024-h457-no?authuser=0
The locomotive service table is always full
There are always about 150 compositions (up to 1,000 wagons) on the layout, so you should always have a reserve
The program keeps records of the operation of each locomotive and after 40 hours warns that it is time for service
Unexpected failures can also occur, so the model is repaired earlier
Models are becoming more complex and more difficult to repair, so it is necessary to have special tools
The latter is self-made
Large machines come in handy for making such things
Records of use are also kept
Offline 1borna
#196 Posted : 08 December 2020 21:52:17(UTC)
1borna
Croatia
Due to the epidemic, the layout was closed to visitors for a long time, but at this time of Advent it was decided to allow visits to a small number of visitors at the same time with strict distance measures.
There are some new vehicles
And a special Christmas train is at the station
Offline 1borna
#197 Posted : 26 December 2020 19:47:47(UTC)
1borna
Croatia
Until I take new photos I will continue with various compositions
UserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImageUserPostedImage
Offline 1borna
#198 Posted : 11 January 2021 20:34:02(UTC)
1borna
Croatia
A lot of new residents came to the cheerful city
Offline 1borna
#199 Posted : 02 February 2021 20:34:24(UTC)
1borna
Croatia
Online marklinist5999
#200 Posted : 12 February 2021 01:06:16(UTC)
Nothing short of "AMAZING!" Great club, teamwork, and that's what it takes. A carpenter, an artist or two, an electrician, an engineer, an electronics expert, a computer whiz.
6 Pages«<23456>
This page was generated in 2.572 seconds.
