Offline twmarklinfan
#1 Posted : 09 August 2019 21:23:47(UTC)
twmarklinfan
For some time I have been looking at the 37786 set. According to the information on the Marklin web site it is fitted with an MFX decoder with up to 32 controllable functions. Has anyone updated their model to add additional sounds?
In particular I would want to add motor sounds.
#2 Posted : 09 August 2019 21:47:58(UTC)
According to the Maerklin site, this model is equipped with Maerklin's OEM MFX decoder and has a number of functions. I do not know if you can modify/add functions to this decoder.
I don't know which decoders can be modified using the Maerklin programmer and whether it can be changed through a Central Station.
There is probably a ESU decoder with sound for the ICE 3. I don't know what modifications might be required to install that one in the Maerklin trainset.
#3 Posted : 09 August 2019 22:57:58(UTC)
The OEM decoders are locked from having sound updates, and you cannot get the original sound file to attach new sounds to anyway. I can't understand what sounds you would want to add anyway, surely it has motor sounds?
I don't recall seeing an ESU ICE3 sound project, but then I haven't been looking for one in my browsing of their projects. It would be worth seeing if Marklin have an ICE3 project in their sound library for the msd/3 decoder.
#4 Posted : 09 August 2019 23:55:59(UTC)
I don't recall seeing an ESU ICE3 sound project......
Of course ESU have an ICE3 sound file - I used it when I converted my 34780 ICE3 to full digital running
https://www.marklin-user...-ICE3-digital-conversion
There's an ICE1 sound file in Marklin's collection of electric loco sound file collection but no ICE3. You might be able to make something up yourself using the Programming Tool.
https://www.maerklin.de/...hruest-decoder-mld3msd3/
#5 Posted : 10 August 2019 00:13:09(UTC)
twmarklinfan
Hi Alan, unfortunately it doesn’t
#6 Posted : 10 August 2019 01:54:35(UTC)
Well, that's a bit lousy.......
The best you might be able to do then is open up the powered car and see what kind of decoder interface is on the MTC board. If it is a 21 pin interface, you should be able to perform a direct swap for the Marklin decoder with an ESU Loksound decoder with ICE3 sound loaded.
Assuming you were buying a Loksound 5, you would go for
ESU 58419 LokSound 5 DCC/MM/SX/M4 "blank decoder", 21MTC NEM6660, with speaker 11x15mm, gauge: 0, H0
Then load it up with the ICE3 sounds
http://projects.esu.eu/p...s/search?cat=7&q=ICE
#7 Posted : 10 August 2019 14:58:45(UTC)
twmarklinfan
I don’t have a programmer but I have found a spare 37788 decoder which should give me the solution.
#8 Posted : 10 August 2019 23:52:43(UTC)
Normally, a dealer should be able to program the decoder for you when they sell it if you tell them what sounds you want.
Good that you've got a solution.
This page was generated in 0.402 seconds.
