Offline Starhawk
#1 Posted : 03 August 2019 08:25:44(UTC)
Starhawk
Is there som way to access function f16 and up (on a loco) withpout buying a CS3?
#2 Posted : 03 August 2019 08:43:53(UTC)
Buy an MS2, but have it updated by someone with a CS3 / CS2 first, as the software update gives the MS2 the ability to control up to 32 functions.
#3 Posted : 03 August 2019 11:14:40(UTC)
Originally Posted by: Starhawk Go to Quoted Post
Is there some way to access function f16 and up (on a loco) without buying a CS3?
If you are referring to a Marklin Loco (factory decoder - mSD/3) then these decoders are capable of operating in DCC mode and as such functions above F15 may be accessed by most any DCC controllers.
If , rather than specifically asking about the Fx buttons, you wish to to use a function that is currently mapped to a Fx button or higher, then you may re-map that function to a lower Fx button.
In a related solution, rather that just reassign a lower Fx button, you might compose a sequence where one button performs 2 functions.
e.g. Station announcement, delay , Conductor whistle ....
The re-configuration options may be done via a CS2/CS3 or one of the programming tools.
Offline Jabez
#4 Posted : 04 August 2019 17:22:26(UTC)
Jabez
Surely if you buy a new MS2 from a dealer it would already be updated, or at least I assume so.
Jabez
6021 will not operate all functions. (Digital)
by jetavdk 06/11/2010 10:02:45(UTC)
This page was generated in 0.347 seconds.
