Offline minirail
#1 Posted : 30 July 2019 14:47:03(UTC)
minirail
Has anybody experienced the failure of the conventional reverse unit on the 35xx class C steam locomotives? The relay buzzes, not what should be a single click when the reverse voltage is applied, the lights change direction, the locomotive does not run. I have disconnected the motor and run it free from the locomotive. The motor runs perfectly. What component has failed? Any answers please?
#2 Posted : 30 July 2019 15:28:05(UTC)
IMO it is a 5 star model running on AC with an electronic inverting unit so the inverter is possibly failing
Offline bph
#3 Posted : 30 July 2019 20:43:20(UTC)
If a component is fried on the electronic board, you can try to replace it, or upgrade the locomotive to digital.
The board in your 3514, should look like this:
https://moba-hgh.de/images/content/stories/firmen/maerklin/BR_018/wueC/3511/281190_3511_FRS_u.jpg
If you decide to upgrade it to digital, you might find this pcb useful.
http://luessi.ch/eshop/oc/index.php?route=product/product&path=2&product_id=54
http://luessi.ch/eshop/oc/image/cache/catalog/8071-500x500.jpg
Offline minirail
#4 Posted : 31 July 2019 08:14:43(UTC)
minirail
Thank you for your answers
Offline Markus Schild
#5 Posted : 31 July 2019 21:17:32(UTC)
Markus Schild
in some cases it helps to shake the locomotive to make the relay work again. Worth a try.
Markus
Offline minirail
#6 Posted : 01 August 2019 17:18:15(UTC)
minirail
Hi Markus
Giving the relay a few good taps did noy help. I think the best solution now is to get Luessi PCB anf fit a Marklin decoder
This page was generated in 0.483 seconds.
