Offline rhNOR
#1 Posted : 20 July 2019 23:35:13(UTC)
rhNOR
I see that Märklin my world is coming out with a building block set for elevated railroads. https://www.maerklin.de/...s/details/article/72221/
As I understand it the my world tracks have the same dimensions and size as the regular C-track so I assume that it should fit, but will the grades be to steep for regular trains?
I'm only setting up on my living room floor and this set looks ideal to add some dimension to the layouts, and looks like it won't take a lot of storage space.
thanks 4 users liked this useful post by rhNOR
#2 Posted : 21 July 2019 18:54:41(UTC)
Looks like a “Lego brick” system allowing for creating individual pillar heights and flexible distances between pillars. Therefore, the inclination - too steep or not - is up to you.
Offline rhNOR
#3 Posted : 21 July 2019 20:41:18(UTC)
rhNOR
Well that's a good point. Smile
But since this is only pillars the track has to support the weight between the pillars, so I'm thinking the pillars should be placed on the track joints.
Looking at the pictures it seems like it needs 5 bricks to reach the height you need for it to pass over other tracks. So if I use the 24188 track I would need 5 tracks with the total length of 94cm.
I haven't found any info on how tall the different "lego bricks" are but it just seems to me that it would be alot steeper than what is suggested in the catalog for the more regular bridges Märklin have.
It doesn't look to expensive so I might get a set when it comes out, but my concern is that I might damage the locomotives if it is to steep.
thanks 2 users liked this useful post by rhNOR
#4 Posted : 21 July 2019 23:30:03(UTC)
Faller do an up and over set. More expensive but it looks better and locos will go over it without any bother. I don't have the part number to hand but it is in their catalogue.
#5 Posted : 22 July 2019 14:48:52(UTC)
Hornby sells track incline sets R909 and R658:
https://www.newrailwaymo....uk/Scenery/inclines.htm
I used some “related” R659 elevated piers on my layout “Hi-Land”.
#6 Posted : 22 July 2019 14:51:36(UTC)
Double entry
Offline rhNOR
#7 Posted : 01 April 2020 09:34:59(UTC)
rhNOR
Don't mean to bump an old thread but thought I'd give an update to what I ended up doing.
It was mentioned in the thread that it looked similar to lego bricks and that gave me the idea, why not just use Lego?
So that's what I did. I went to a store where I could pick the lego bricks i wanted and buy them by the kilo.
Result ended up like this:
Personally I feel this is a better solution than the building blocks I was first considering since I have more flexibility in height increments.
Thanks for all your input :)
Offline Jimmy Thompson
#8 Posted : 01 April 2020 12:25:05(UTC)
Jimmy Thompson
And you could choose the colors that you want, instead of what is supplied ThumpUp
and you can build a whole LEGO city to go with:
Jimmy T
Dr Dirt's Rule #1 and
Offline rrf
#9 Posted : 01 April 2020 12:52:58(UTC)
rrf
Nice!
I'll have to experiment with this on the kids' layouts. Have you figured out a good ratio of Lego blocks to track length (for example: 1 x standard brick per 360 mm of track)?
Rob
Mackenrode Wende Bahn
thanks 1 user liked this useful post by rrf
Offline rhNOR
#10 Posted : 02 April 2020 11:22:54(UTC)
rhNOR
Originally Posted by: rrf Go to Quoted Post
Nice!
No I haven't. This is the highest point and if I had to guess I'd say that it took me about 1,5m to get there.
It uses a lot more bricks than i first thought so I had to go back the the store a couple of times. It is also possible to add those 1/3 pieces to adjust the height even more. I try to place the "pillars" for every piece of track but I also make sure that the track is always resting on the lego even when a train is not on the tracks. So it takes some adjustments to get there but I'm quite happy with the result.
Not exactly very prototypical but I'll survive. :)
thanks 1 user liked this useful post by rhNOR
#11 Posted : 02 April 2020 12:14:33(UTC)
Jimmy Thompson
rfNOR said:
"Not exactly very prototypical but I'll survive. :)"
I feel a "There's a prototype for everything" challenge coming on LOL
I will get started on the search (I have my Indiana Jones hat on and away I go...)
Jimmy T
Offline TEEWolf
#12 Posted : 02 April 2020 13:10:48(UTC)
Nice!
I had and still have the same ideas as @rhNor had, even with the one with the Lego stones. But I have not yet made up my mind.
If you are using MyWorld for your kids, than it makes sense to use this "Hochbahn" (is it high rise tracks?). Starting set is article #29307, then #23302, then #72221 and the bridge #72218. But only 72221 and 72218 has no plastic tracks inside. These tracks are for electric MRR useless and you can throw them away. Not, if you use MyWorld for kids anyway. The construction by these stones are very easy, because the asent and descent is always only one stone after another up to a maximum high of 4 stones. Then your underpass by other trains is possibe. The crosspiece is perfectly fitting for all C-tracks as well, because this MyWorld can be used with every C-track as well. But the other way around is impossible. MyWorld is a battery operating (therefore more or less a non electrical) toy.
And indeed these packages 72221 and 72218 are not expensive and not bad for any carpet railroader like myself.BigGrin
See more pictures for your information in the MyWorld catalogue (major pages are 19 and 20)
MyWorld catalogues
This page was generated in 0.523 seconds.
