#1 Posted : 06 July 2019 11:38:49(UTC)
Märklin says that only one product allows alone on the track when you shall program a locomotive or accessories by the MS2.
This make some tired way to pull off the trains and accessories every time from the track when you shall programming.
So i did draw a picture to show you easy way which you need only switch over to program track or and connection.
Attention!
Do not connect to the program track or connection while the power is still on.
Recommended is to connect while the power is off.
Same way when you change the dip switch and the power must be off.
Just simple press on the button "Stop" on the MS2.
#2 Posted : 06 July 2019 13:45:45(UTC)
Why not just disconnect the main track while programming ??
There's no need to disconnect the programming track when you're just running trains. Cool
That way you can have a part of the layout used for programming; but still use that part when not programming. Cool
#3 Posted : 06 July 2019 14:03:48(UTC)
What the hell are you writing about???
Read my post and watch my diagram!!
Offline poulmh
#4 Posted : 06 July 2019 14:27:34(UTC)
poulmh
I will set my money on Purellum
____________
Poul M Hansen
thanks 1 user liked this useful post by poulmh
#5 Posted : 06 July 2019 17:36:26(UTC)
I'm just trying to tell you that if you remove 75% of your diagram, using a SPST switch instead of the DPDT,
you will increase the functionality of your layout to 100% when not programming........... Laugh
This is all you need:
spst
And then it will work better........ BigGrin
Maybe you have a friend who can explain to you how electricity works; I think it's too big a task for me. LOL
Offline MaerklinLife
#6 Posted : 06 July 2019 19:39:17(UTC)
MaerklinLife
When I had the same challenge years ago, I found this article helpful:
https://railway.zone/pos...Marklin-Mobile-Station-2
Of course, you don't need to use the Märklin-boxes, but the idea worked for me.
thanks 2 users liked this useful post by MaerklinLife
This page was generated in 0.274 seconds.
