Offline LongHairedDavid
#1 Posted : 02 July 2019 12:22:01(UTC)
LongHairedDavid
Every so often the lok stops with a traction tyre wrapped around the valve gear!
Sometimes both of them come off and the only way to sort it is to take the body off and tease them back into place. Is there anything I can do to stop them coming off in the first place?
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
#2 Posted : 02 July 2019 12:37:37(UTC)
Stop doing burnouts on the layout.. LOL
Are you sure that you have the correct tyres on the loco? I used to have lots of V60s and I can't recall shredding any tyres.. Put some new ones on anyway - once they come off they will not stay on properly..
#3 Posted : 02 July 2019 12:53:03(UTC)
LongHairedDavid
Lok is only 3 months old so original tyres. Just got an order on its way from Lippe so I guess new ones will have to wait :-(
Long Haired David
Offline Rwill
#4 Posted : 02 July 2019 13:10:56(UTC)
Rwill
As usual on eBay from my favourite "spare part" supplier in Italy very good price and postage:
www.ebay.co.uk/itm/MARKL...2035?hash=item2f26228f53:g:8KsAAOSwPrtb7V4M
#5 Posted : 02 July 2019 13:22:10(UTC)
LongHairedDavid
Well that's done then. I am an active EBay user but never thought to look!
Thank you
Long Haired David
#6 Posted : 02 July 2019 13:31:56(UTC)
What are you pulling with the Loco?
#7 Posted : 02 July 2019 13:45:01(UTC)
Maybe its an older model, and has spent years on the shelve in the shop, causing the tyres to go brittle¿?
#8 Posted : 02 July 2019 13:46:48(UTC)
LongHairedDavid
It's my yard shunter so not much in terms of load. Max 5 wagons, I should think.
Long Haired David
Offline IanC
#9 Posted : 02 July 2019 14:38:08(UTC)
IanC
Have you oiled it recently or squirted anything with WD40? It all runs down to the wheels eventually and gets between the metal and the rubber and the tyres peel off on rotation. Pulling a loco along the track unpowered as a dead weight will also stretch the tyres. Just a thought. IanC
thanks 1 user liked this useful post by IanC
#10 Posted : 02 July 2019 14:47:58(UTC)
LongHairedDavid
Hmmm. No oiling but I have been known to rub the loco back and forth a couple of times over a dirty piece of track. That's a habit I will stop now!
Long Haired David
#11 Posted : 02 July 2019 20:27:48(UTC)
Pushing any rubber tired Loco against the friction of the track will be all it takes.
Just think about what the thin soft tyres will do when faced with that?
I suspect your problem may mysteriously vanish.
Offline Maurice
#12 Posted : 09 July 2019 00:44:28(UTC)
Maurice
I had the same problem a few years ago and it went away when I fixed a K track joint that was not properly connected - it was not smooth when I ran a finger over the rail join.
Not sure if this was the cause but it has not happened again.
Maurice.
#13 Posted : 09 July 2019 08:41:33(UTC)
pushing forward and backwards is your problem, if you push somebody forward and backwards the also will lose their patience.
#14 Posted : 09 July 2019 11:11:33(UTC)
LongHairedDavid
Maurice.
I only use it in the yard so that isn't an issue. Thanks for the idea.
Long Haired David
#15 Posted : 09 July 2019 11:15:16(UTC)
LongHairedDavid
I think that you are probably right. I will stop doing it and clean the rails!
Long Haired David
This page was generated in 0.465 seconds.
