Offline Pablinmark
#1 Posted : 27 June 2019 02:07:10(UTC)
Pablinmark
Argentina
Location: Ciudad Autonoma de Buenos Aires, Buenos Aires
Hello, i've got my Marklin Mobile Station 2, it works fine with my new C tracks. But can anybody tell me if there is info available about maximum power output, or consumption in terms of Locos and wagons?, I just wondered this after tried some of my lighted wagons, like 4089, 4032, 4411 etc. How many lighted wagons can i use on my layout before burn my MS2?? or How many Locos running at the same time? BTW, I started with a 29060 digital set. Thanks!!Cool
Offline TEEWolf
#2 Posted : 27 June 2019 02:30:53(UTC)
Max. output of a MS 2 is always 1,9 A.
Offline Pablinmark
#3 Posted : 27 June 2019 02:42:02(UTC)
Pablinmark
Argentina
Thank you very much!! Smile
Regards!
Offline TEEWolf
#4 Posted : 27 June 2019 02:52:27(UTC)
Sorry I forgot.
Have a look at your software version of your MS 2. The actual vers. is 3.5.5.
For more and detailed information see this post on the forum
https://www.marklin-user...-for-32-Function-support
Offline Pablinmark
#5 Posted : 27 June 2019 03:31:21(UTC)
Pablinmark
Argentina
Sorry I forgot.
Oh thanks for the reminder. So, what i need to do this, is to have a Central station2 with internet access? or could be another way?
#6 Posted : 27 June 2019 20:46:27(UTC)
You need a Central Station to update the firmware on the MS2. If you can find a model shop that has one you can get them to update the firmware.
I also don't have a CS, but later in the year, when my yearly shipment from my US dealer is coming, I'll ship my MS2 to them, so they can update the firmware and then just ship it back with the rest of my order. I'd be without the MS2 of course... but short of finding someone with a CS thats the only option I have.
#7 Posted : 27 June 2019 23:02:28(UTC)
Views messages in topic : 3,530
You will not "burn" your MS2, the over-current protection will shut it down.
As to how many lighted wagons or locomotives you can run can't really be answered, it depends on the type of locomotives, the speed you run them, how many wagons they are pulling etc.
Depending on which ( and how many ) locomotives you have, updating the software might not give you anything useful.
#8 Posted : 27 June 2019 23:03:39(UTC)
The other option is finding someone else with an ms2 that has been updated and plugging your ms2 into the same system as their updated ms2 is connected to. The updated ms2 will then copy the files to the one that needs updating.
And for Minok, maybe get a second ms2, so while one is away being updated you still have one to play with that will update itself when the other one comes back ... BigGrin BigGrin BigGrin
#9 Posted : 29 June 2019 08:54:57(UTC)
You cannot write depends or depending when you know yourself that the box to the MS2 do have power feed maximum at 36 VA.
It doesn´t how many locomotive and the wagons with the light are on the track, it´s the power feeder that counts.
In this case 36 VA.
#10 Posted : 29 June 2019 09:26:07(UTC)
In this case 36 VA.
Hear, hear!
I have H0 gauge trains that consume only 0.2 A while another train consumes 1.5 A.
I can easily run 6 trains if I pick low-power trains only.
I can easily get an overload situation when running two high-power trains.
I cannot count 36 VA, but I can count trains.
BTW: 36 VA is the wrong answer. 36 VA is the output of the power supply, the output of the track box will be significantly lower in that case.
The output current of the track box is limited, not the wattage. By using a power supply with a slightly higher voltage you can squeeze some extra Watts out of the track box.
1.9 A is the answer, 36 VA is not correct.
#11 Posted : 29 June 2019 09:27:00(UTC)
In this case 36 VA.
Please read my post again and then try one more time, this doesn't make any sense at all.
#12 Posted : 29 June 2019 11:09:34(UTC)
In this case 36 VA.
Hear, hear!
Watt is effect.
That is, energy in consumption.
Amps are electric current.
When you read Märklins power supply, they present 60 VA or 100 VA as energy consumption.
By the way...there is component you can read energy consumption.
We call it Wattmeter.
#13 Posted : 29 June 2019 11:34:00(UTC)
Watt is effect.
Yes; but in this case Watts is totally irrelevant, since the MS2 measures the current, and shut off at 1,9 Amps. Cool
No, the consumption is not 60 or 100 VA; but higher.
The 60 or 100 VA you read on the power supplies are the rated output. Cool
And again, just to be sure; the rated OUTPUT in VA of the power supplies
has nothing to do with the rated CURRENT output of the MS2. Cool BigGrin
#14 Posted : 30 June 2019 00:58:31(UTC)
Watt is effect.
Watts is effect, that is energy in consumption.
Buy a wattmeter and connect it on the wall socket.
Connect power supply like Märklins 66360 to the box with the MS2 and start drive locomotive.
You will see result how much locomotive draw in watts.
Offline TEEWolf
#15 Posted : 30 June 2019 02:48:30(UTC)
A flux of 1 A over a voltage of 1 Volt (V) means a power of 1 Watt (W).
Sorry, I do not have a vector graphics software to show it in a formula.
Well, but as @H0 mentioned already, the current consumption can be very different by a loco.
#16 Posted : 30 June 2019 08:31:36(UTC)
Because pressing the meny-button on the MS2 to get the actual output current measured in Amps is far too complicated ?? LOL LOL LOL
#17 Posted : 30 June 2019 09:56:20(UTC)
Watt is effect, that is energy in consumption.
#18 Posted : 30 June 2019 12:50:52(UTC)
Edited: I give up.
Remember Mark Twain LOL
#19 Posted : 30 June 2019 15:07:28(UTC)
LOL LOL LOL LOL LOL LOL
#20 Posted : 30 June 2019 15:28:11(UTC)
Mark Twain as pen name was an American writer.
What has this person to do with the topic? Confused
#21 Posted : 30 June 2019 15:31:48(UTC)
About as much as measuring or calculating Watts. Laugh
#22 Posted : 01 July 2019 20:55:20(UTC)
Iceland is in the North Atlantic, and its capital is Reykjavík....
#23 Posted : 02 July 2019 09:28:13(UTC)
#24 Posted : 02 July 2019 12:11:32(UTC)
This setup will tell me how much the power supply consumes, but it will not tell me how much power the trackbox can supply.
Those who are in the know know it. Cool
1.9 A is correct. Software upgrades will not increase the power output. Actually it is the power output of the trackbox, not the power output of the MS2 handheld unit.
Software upgrades can fix bugs and bring more features.
thanks 6 users liked this useful post by H0
This page was generated in 0.852 seconds.
