Offline Rwill
#1 Posted : 21 June 2019 14:34:12(UTC)
Rwill
After a morning on the trains my attention was needed elsewhere by management so I got up and walked out of the train room leaving CS2 powered on, M84/83 flashing, hobby signals on and a couple of loks with lights on. 24 or more hours later I returned and everything appears to be as I left it and other than a very old early digital lok with old light bulbs feeling rather warm everything seems fine. Have I "got away with it", should I expect trouble ahead, or is this perfectly OK and normal?
Offline michelvr
#2 Posted : 21 June 2019 15:42:03(UTC)
michelvr
Rwill,
My motto is when it comes to anything electrical turn it off when done. Or just like tending a fire, put it out when you're done with it!
BTW I fly radio control airplanes so when I charge anything I stay close by and keep my eyes 👀 on it! I'm not one to tempt fate!
thanks 2 users liked this useful post by michelvr
Offline rmsailor
#3 Posted : 21 June 2019 16:04:24(UTC)
rmsailor
The problem with any digital controller is that it supplies a constant full voltage and a fairly high current (amps) before the cutout acts. This then has the potential to develop a lot of heat with possible catastropohic results if you have a partial short circuit. So always switch off and preferably unplug from the wall socket
Bob M.
thanks 2 users liked this useful post by rmsailor
#4 Posted : 21 June 2019 19:07:25(UTC)
This is to be expected. Leaving such an appliance turned on should not be an issue.
The suggestions to always turn it off (as you usually do) is because there is always some risk involved.
I have installed a small LED (that is connected to my layout power system) on the stairs going up out of my basement so if I go up the stairs without turning power off, I can notice that the power is still on. I have may layout plugged into a smart plug, so if I see it is on, I can simply use a voice command to turn it off via the Google assistant.
thanks 6 users liked this useful post by DaleSchultz
Offline dominator
#5 Posted : 22 June 2019 01:45:14(UTC)
dominator
Hi Dale, that's a great idea. What device do you use to turn off your system by voice command.
Dereck
Northland. NZ
#6 Posted : 22 June 2019 04:13:06(UTC)
I've done this many times, even when I only intended to 'pop upstairs for a minute', then get distracted and not come back down at all.
Of course, ideally, you would switch everything off, (at the wall), but how many do so with their TV?, or just turn off at the remote, the TV is still 'on' of course, mains voltage still present into the unit.
Same with the Freeview box, DVD player, your PC, Monitor, Printer, Router?, standby is low power-consumption ready for fast wake-up, it's not "OFF".
Fridges run all the time, most Ovens, Microwaves have a clock, always on. Most of us probably charge our phones, tablets etc overnight. Bedside clock is another.
Statistically the risk of damage (fire being the highest) is very low, but of course it does happen.
We'd like to think the Loco's Accessories etc are designed and manufactured to a standard that allows for them being permanently powered without coming even close to any overheating, but we all know we sometimes have mis-matched lamps etc than may be producing more heat that is desirable.
I think now and then you'll be fine, but perhaps not make a habit of it BigGrin
#7 Posted : 22 June 2019 04:58:20(UTC)
Well, you don't even have to have stuff plugged in and in standby to have fire risks......
I think I posted in another thread a picture of some damage done to my house wiring by a mouse. The wires in question were intermediate straps for my hallway lights, where I can turn the lights on or off at any of the 4 switches in circuit. This meant that all three wires in the cable carry phase power, and they are only energised when the switches are in certain combinations. In trying to find the problem we (an electrician friend from our club and myself) got the switches into a combination where the lights started flickering badly and we could hear arcing and smell electrical burning.
After bashing holes in the plaster board downstairs and upstairs we found the issue. It looked like a mouse got into the cavity between ceiling joists and to find a way out tried to chomp through the cables that were going up through the wall.
The hole that the mouse tried crawling up through - you can see clear burn marks
The same hole from above
The wires we pulled out. New wires were spliced in to repair the damage. I also squirted (on Per's recommendation) some expanding foam into the hole to prevent a repeat.
My electrician friend said it was the worst he's ever seen. He is also an electrical engineering tutor at the local Polytech, so took the wires to work, where they were put on display for students to see!
Crispy mouse anyone??
A few holes had to be cut into ceilings and wall to find and repair the issue.
Offline ocram63_uk
#8 Posted : 22 June 2019 13:04:43(UTC)
ocram63_uk
when I have to leave the trains for some odd reason I always hit the 'OFF' button on the EcoS, this cuts power to track and accessories leaving the EcoS on and in stanby but no power is sent anywhere on the layout.
HTH
#9 Posted : 22 June 2019 13:27:40(UTC)
I always switch the power off from the model railway when i don´t use it.
Offline LongHairedDavid
#10 Posted : 22 June 2019 14:29:54(UTC)
LongHairedDavid
I have a Teckin Smart Plug from Amazon logged into my Alexa. It switches all of the extension leads that I have under the railway that power the ECOS and all the Wallwarts for lighting, Arduinos etc. A simple "Alexa, turn railway off" does the job. "Alexa, turn railway on" gets me going again. Simples!
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
#11 Posted : 22 June 2019 15:38:12(UTC)
I check plugs and sockets in each room at night. All I leave is the TV on standby along with the cable box (Virgin Media in the UK)
New Zealand in known for its man eating mice.
Offline TEEWolf
#12 Posted : 22 June 2019 17:52:05(UTC)
And I thought, Keas are the nasty KiwisLaugh
https://upload.wikimedia...4/Kea_bei_der_Arbeit.jpg
#13 Posted : 22 June 2019 21:31:38(UTC)
Dereck
I have my big 16VAC power supply as well as my DC power supply plugged into a power strip that runs though a 'smart plug' - in this case made my Leviton. I can control it via any of my Google assistant devices, by saying "turn off Intellibox"
(In addition, my software will power off the track current if there is no activity on my layout for 5 minutes.)
#14 Posted : 23 June 2019 00:47:22(UTC)
Yeah, an NZ car insurance company made an a TV advert by taking a small car up into the mountains and setting up a camera that must have been movement activated to film the keas demolishing it. A David Attenborough fronted 3 part item on them is here on Youtube.
Guest (7)
This page was generated in 0.466 seconds.
