Offline mgbeck_98
#1 Posted : 17 June 2019 08:06:59(UTC)
mgbeck_98
I have two buss wires for Digital(red) and Ground(brown) encircling my layout powered by my CS2. It does not power switches it is only for the digital control signal. My decoders are separately powered. I'd like to add a lighting buss to my layout powered by the yellow output of a standard trafo (ala Ma 6631). I'd rather not add in a separate ground for this circuit. Can I combine the brown outputs from the CS2 and Blue Trafo like the following without any ill effects?
Offline amartinezv
#2 Posted : 17 June 2019 09:59:51(UTC)
amartinezv
Yes you can, no problem
Antonio Martínez
www.raildigital.es/davidruso
thanks 2 users liked this useful post by amartinezv
#3 Posted : 17 June 2019 12:55:23(UTC)
Generally yes, but which controller type and version you have will have an influence as will booster types.
Early versions of the CS2 did not have galvanic isolation, neither does the CS3, but the CS3+ does. You can only have one of these devices powering your layout, everything else powering the layout must be galvanically isolated if you're using a common 'brown'.
Likewise 60173 boosters are not galvanically isolated but 60174 and 60175 are. Same rules apply.
Offline mgbeck_98
#4 Posted : 17 June 2019 14:37:35(UTC)
mgbeck_98
Thanks, but what effect does not having galvanic isolation have?
#5 Posted : 17 June 2019 15:24:08(UTC)
None at all in your case. Since Märklin transformers have galvanic insulation and since they are simple analogue devices, you can use your bus wires as intended, even if your CS2 does not have galvanic insulation.
At any time there should be only one digital device without galvanic insulation connected to the track. But this does not apply to your bus wire.
Offline mgbeck_98
#6 Posted : 17 June 2019 22:59:59(UTC)
mgbeck_98
I looked up galvanic isolation, so I know what everyone is talking about.
Offline dickinsonj
#7 Posted : 19 June 2019 01:23:26(UTC)
Ahhh, Thank you. Finally an answer about this topic which makes complete sense to me and clears up what had caused me some confusion. ThumpUp
Buss wiring (H0-scale)
by Mr. Ron 08/09/2021 03:11:11(UTC)
Question Re dcc layout and buss wiring (Digital)
by ShannonN 23/08/2016 02:54:23(UTC)
This page was generated in 0.348 seconds.
