Offline Cheshy
#1 Posted : 06 June 2019 22:38:52(UTC)
Cheshy
hallo everyone
i would like to use this track plan:
and add some extra shunting on the bottom right around here:
the idea would be that the loco pulls coal or ore from the bottom left, drives some circles and then drops the cargo at the bottom right were a shunting loco moves them around to "empty" them. I have no idea what would be a good part to add there as i have no experience tbh in adding stuff. If i would be building it now it would take up some empty space. Thx in advance
#2 Posted : 07 June 2019 12:25:44(UTC)
Please remember that you also need access. Comfortable arm reach length is normally 60 cm. By "sealing" the area marked by the red frame you would make your life miserable.
I allow myself to show a shunting-oriented layout - even with a hump yard (see item #9) - on a similar surface as the original Maerklin plan. The theme could be adapted to your preferences.
This is plan #21 for Maerklin K track (385 x 175 / 140 cm) presented in "0700 Maerklin Gleisanlagen Spur H0 fuer K- und M-Gleise"; a PDF of the 1982 track planning book can be found here:
https://dermodellbahnblo...plaene-gleisanlagen.html
Offline Cheshy
#3 Posted : 07 June 2019 12:41:25(UTC)
Cheshy
The main reason i wanted to add something is because the freight loco isn’t goin anywere. Feels a bit weird.
This page was generated in 0.227 seconds.
