Offline ShannonN
#1 Posted : 05 June 2019 13:21:09(UTC)
ShannonN
Hi all
I have 2 MS2 controllers and I am building two different shelf layouts. 1 is European in design running all my Marklin stuff.
1 will be American in design running 2 rail in DCC mode with a US style SD 40 digital loco. I need to know how to connect the MS2 for 2 rail operation, like which colour wire to use for left rail and which for right rail etc
Cheers Shanny
#2 Posted : 05 June 2019 13:53:36(UTC)
This does not matter with DCC or mfx or modern MM loco decoders.
Lift the loco, turn it around and you will have swapped "left" and "right" anyway.
Just make it consistent if you have more than one feeder track. Using red for the "right" rail can help in doing so.
Offline TEEWolf
#3 Posted : 05 June 2019 17:18:27(UTC)
Hi all
Cheers Shanny
You have 2 controllers - good, but do you have 2 track boxes as well? One for Märklin and one for Trix? Cabeling is identical. Red for Bahnstrom (= B) and brown for Masse (= 0)
And look into the manuals
http://medienpdb.maerkli...e-Station_Trix_DE_EN.pdf
https://static.maerklin....f3c36e4fb91557845024.pdf
(page 21 - but you have to update your MS 2 to software version 3.55 - this includes a update of your track boxes to vers 1.41)
For updating see this thread
https://www.marklin-user...-for-32-Function-support
This is more a general information
https://static.maerklin....57ac95a9a31493730041.pdf
#4 Posted : 05 June 2019 17:49:17(UTC)
You have two MS2?
The first can be use with mfx and the second only DCC protocol.
It´s enough to use just one box but the power feeder are maximum 36 VA which should handle about 3-4 digital locomotives with the sounds on.
Offline ShannonN
#5 Posted : 05 June 2019 18:13:55(UTC)
ShannonN
Yes I have a Märklin track box for each, soon to be updated to latest version when I am down in Brisbane at the end of the month
This page was generated in 0.288 seconds.
