Offline morsing
#1 Posted : 03 June 2019 14:16:51(UTC)
morsing
My 39674 MFX loco stopped moving one day. It's making the right noises, just not going anywhere. I tried deleting and re-registering on my CS3, but it didn't help.
What could cause this? And how do I fix it?
Marklin C-track + CS3+
Offline bph
#2 Posted : 03 June 2019 15:41:07(UTC)
Have you checked for disconnected joints on the drive shafts?
If they ore ok, then its most likely the decoder or the motor.
Offline morsing
#3 Posted : 03 June 2019 16:03:55(UTC)
morsing
I haven't had the top off, but I just tried to spin the driven wheels and I definitely can't move them. I'm pretty sure this is a software fault.
Offline morsing
#4 Posted : 03 June 2019 17:30:38(UTC)
morsing
I've reset the loco completely now, and tried running it with sounds off. Can't here anything. It's not even trying...
#5 Posted : 03 June 2019 17:44:48(UTC)
Try to pull off decoder from the PCB and put back again.
Make sure locomotive does not have power on the track.
It´s possible decoder defaults.
Offline morsing
#6 Posted : 03 June 2019 18:19:04(UTC)
morsing
I've just taken it all apart, measured the motor got power as well. I took the base out and the driveshafts off, and the motor started spinning. I am now trying to get the driveshafts back on, which is not easy!
Offline morsing
#7 Posted : 03 June 2019 19:37:34(UTC)
morsing
It's running again, no idea what went wrong.
Spent an hour trying to fit the coupler spring though, and lost it in the end. Not sure it's worth buying a new one, if I can't actually fit it.
This page was generated in 0.274 seconds.
