Offline Thewolf
#1 Posted : 02 June 2019 15:46:41(UTC)
Thewolf
Hi guys Cool
Considering the gloomy weather in Longueuil, I'm doing tests with Anyrail in preparation for next year's future layout
And I come across a problem.
Look at curve 24430 on the right: a piece of rail is missing in a curve
Did I make a mistake somewhere? Apparently, no. Is it something else? A little Anyrail bug?
Have a nice day
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline PeFu
#2 Posted : 02 June 2019 16:26:57(UTC)
PeFu
Oh yes, it’s you! BigGrin I repeat myself from your previous post on:
https://www.marklin-user...ith-Anyrail-in-this-plan
Between R3 and R4, you can’t have 246xx turnouts. You need 247xx turnouts, as the distance between R3 and R4 curves should be more narrow than the distance between R2 and R3 curves. Changing software will give the same result.
There are other ways to solve this, however, you need a distance of 64.3 mm between R3 and R4. Between R2 and R3, distance is 77.5 mm.
Offline Thewolf
#3 Posted : 02 June 2019 20:55:11(UTC)
Thewolf
PeFu I'm stubborn, I know that. Cool
In this exercise, I did the same thing on the left and there everything is correct, but without starting a curve with 24671
On the right, except that I started from further away with a curve at the beginning with 24671 and 24672
For the curve on the left in the second drawing with 24671, I referred to this
So there's a problem in the second drawing
If you have time, do both exercises with your software to see
Thewolf
#4 Posted : 02 June 2019 22:35:19(UTC)
.... So there's a problem in the second drawing ....
There is nothing wrong with the drawing , it has depicted what the drawer laid down.
i.e.
Inner trackspacing at the top let = 77.5mm (as per 24671/2 track pieces for a R1<>R2 spacing)
Outer trackspacing at the bottom right = 64.3mm (as per R3<>R4 spacing)
If the intent was for the tracks to meet then you need to lay down more appropriately dimensioned track pieces.
Offline Thewolf
#5 Posted : 02 June 2019 22:52:22(UTC)
Thewolf
i.e.
Thank you.
The only thing left for me to do is to reproduce the second drawing in reality. I will when I dismantle the layout before I move.
It has to work for the new layout next year.0
I'm moving on now.
Thewolf
Offline PeFu
#6 Posted : 02 June 2019 23:55:02(UTC)
PeFu
As clapcott explains, the problem is that you switch from R1-R2-R3 in the upper left corner, to R4-R3-R2 in the lower right corner. There should always be 64.3 mm between R4 and R3, everywhere else you have 77.5 mm.
I would propose that you do the same drawing using R3-R4-R5 only, and 24771/72 as well as 24711/12 turnouts.
Offline Thewolf
#7 Posted : 03 June 2019 01:15:25(UTC)
Thewolf
Hello PeFuCool
I will see that in a few months...it will all depend on the family room I have in July 2020.
I would like to reproduce the same layout I have now: I have seen the mistakes I made in design and construction. It's all in one file.
I want to deepen Itrain's automatisms on the current layout which, given our decision to leave, has only one level. I will put pictures in the next few days in Laurentides-Neutsdadt III
Thewolf
This page was generated in 0.419 seconds.
