Offline Thewolf
#1 Posted : 31 May 2019 19:11:36(UTC)
Thewolf
Hi guys Cool
I have to review the track schematics of my layout, at least in some places.
Can someone tell me what's going on here?
Or is it Anyrail's problem?
Or is it my fault?
What did I forget in the circle?
Do I have to change software?
Thank you
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline PeFu
#2 Posted : 31 May 2019 19:57:20(UTC)
PeFu
Between R3 and R4, you can’t have 246xx turnouts. You need 247xx turnouts, as the distance between R3 and R4 curves should be more narrow than the distance between R2 and R3 curves. Changing software will give the same result.
Offline Thewolf
#3 Posted : 31 May 2019 20:29:55(UTC)
Thewolf
Thank youy PeFu Cool
I think now that this is correct .
It's a test for the layout of the future housing
Have a nice day
Thewolf
Offline rrf
#4 Posted : 31 May 2019 20:30:53(UTC)
rrf
One can also use a combination of 24064's and 24077s at the 90 degree point of your curves to adjust the R3 / R4 / R5 track separation of 64 mm to match the the R1 / R2 / R3 track separation of 77 mm. (or vise versa).
Rob
Mackenrode Wende Bahn
Offline Thewolf
#5 Posted : 31 May 2019 20:39:04(UTC)
Thewolf
Thank you rrfCool
Very appreciated for the future
#6 Posted : 31 May 2019 23:49:14(UTC)
Have a nice day
Thewolf
Nearly correct.
The straight leg of the 24711/2 also needs a 24071 between it and the 24172. The 24711/2 on the middle track will also need a 24071 on its straight leg. Check the diagram in the Marklin catalogue and you will see what I mean.
Offline Bones
#7 Posted : 01 June 2019 15:45:33(UTC)
Bones
Sadly Wolf it was your fault
You failed to allow for the smaller spacing between the 2 largest radii, however you won't be the last if that consoles you
Offline Thewolf
#8 Posted : 01 June 2019 16:02:07(UTC)
Thewolf
This is Thewolf, not WolfMad
Offline Thewolf
#9 Posted : 01 June 2019 16:05:10(UTC)
Thewolf
Have a nice day
Thewolf
Nearly correct.
Thank you Alan Cool
You are right .
I'm very distracted these days.
Now this is correct
Thewolf
#10 Posted : 01 June 2019 16:54:51(UTC)
Thank you Alan Cool
You are right .
Now this is correct
Thewolf
Yep, that is much better. ThumpUp
Offline Bones
#11 Posted : 04 June 2019 05:47:02(UTC)
Bones
Sorry didn't mean to be rude
Offline Thewolf
#12 Posted : 04 June 2019 15:28:18(UTC)
Thewolf
No problem Cool
This page was generated in 0.487 seconds.
