Offline Hics
#1 Posted : 19 May 2019 09:52:00(UTC)
Hics
Hi guys.
I searched the forum for a similar topic but couldn't find one.
Anyway, I'm thinking about making test track by myself. Have you ever done one? Any clues or ideas?
thanks 4 users liked this useful post by Hics
Offline tiono
#2 Posted : 19 May 2019 14:38:16(UTC)
tiono
Do you mean; Rollenprüfstand ? (like this: Marklin rollenprufstand )
I built one myself, simple wooden construction and some ball bearings. So far it is working fine, although the ball bearing position can not be adjusted. Photo below:
thanks 14 users liked this useful post by tiono
Offline Hics
#3 Posted : 19 May 2019 17:37:28(UTC)
Hics
Originally Posted by: tiono Go to Quoted Post
Do you mean; Rollenprüfstand ? (like this: Marklin rollenprufstand )...
This is exactly what I'm looking for.
Interesting idea. Any more guys?
Offline costing
#4 Posted : 19 May 2019 22:59:02(UTC)
costing
Same idea, small ball bearings but this time mounted on L-shaped aluminium profiles, allowing any piece of track to be a test track.
thanks 8 users liked this useful post by costing
Offline Hics
#5 Posted : 20 May 2019 14:27:31(UTC)
Hics
Thanks for a picture. I can find them as well. I'm actually looking for someone who has made it and can give details of what to use and how to do it.
I have just found this:
http://www.forotrenes.co...wtopic.php?f=6&t=983
thanks 2 users liked this useful post by Hics
Offline costing
#6 Posted : 20 May 2019 19:13:36(UTC)
costing
That's another very nice build. Here are the parts that I have used. Original drawing is here.
thanks 4 users liked this useful post by costing
Offline Hics
#7 Posted : 21 May 2019 13:10:02(UTC)
Hics
This is great.
How far did you put bearings from eachother?
thanks 1 user liked this useful post by Hics
Offline costing
#8 Posted : 21 May 2019 14:44:00(UTC)
costing
16.5mm = the distance between the regular tracks in HO scale.
thanks 1 user liked this useful post by costing
Offline Hics
#9 Posted : 21 May 2019 15:03:19(UTC)
Hics
I meant the distance between axis?
Offline costing
#10 Posted : 21 May 2019 15:16:52(UTC)
costing
Right, sorry :) As close as possible without actually touching. So probably something like 6+1mm. Will double check when I get home.
Offline Hics
#11 Posted : 21 May 2019 15:34:20(UTC)
Hics
No worries.
But did you put anything in this ares to stop ball bearing from scratching the alu piece?
Offline costing
#12 Posted : 21 May 2019 15:55:09(UTC)
costing
I though of the same but there was no need for it. A burr on the alu inner side is enough spacer. So for once don't clean up that hole after making/threading it :) If not enough then give it a tap from outside, the alu will easily bend and make a micro "cone" on the other side.
I've also applied a touch of CA glue between the bearings and the axle/screw, as the shrink tube was not a very precise spacer.
Offline Hics
#13 Posted : 22 May 2019 23:48:41(UTC)
Hics
Ball bearings ordered. All the other parts are easy to find and probably in a garage somewhere Wink
Half term is coming and this time it's my time to stay with kids so hopefully should have it ready for bank holiday BigGrin
Did you measure this distance?
Offline costing
#14 Posted : 23 May 2019 07:55:53(UTC)
costing
Yep, it's as mentioned before, 1mm between bearings, so the side holes/axle centers are 7mm apart.
Enjoy your/their vacation time ;)
Offline Harryv40
#15 Posted : 23 May 2019 08:47:44(UTC)
Harryv40
Hi Guys
I just wished I had the skill to make one, unfortunately, I don't have the knowledge of where to get the parts, the tools to make it and finally the patience to do.
My fingers are like sausages doing this type of thing! How about offering to make them for members and charge them for your time and parts!
As my daughter would say 'winner, winner, chicken dinner' please don't ask me what it means, I don't talk 18 year old girl!
Harry
Offline Hics
#16 Posted : 23 May 2019 10:45:03(UTC)
Hics
Originally Posted by: Harryv40 Go to Quoted Post
Hi Guys...How about offering to make them for members and charge them for your time and parts!
Hi Harryv40.
This looks like an easy project but it is probably gonna take few evenings and a few f... words. And at the end it won't look any as good as product you can buy at shop. And if I charge you for this you will be f.... wording me. Therefoe let me recomend you this one.
https://www.ebay.co.uk/s...kw=DCM-RRA6&_sacat=0
https://www.youtube.com/...inue=1&v=32WEtcW73nw
I'm thinking about buying it for myself.
Offline dickinsonj
#17 Posted : 24 May 2019 01:23:34(UTC)
You mean that it is possible to get through a MRR session without any F words? Now I have something to aspire to. BigGrin
Offline Hics
#18 Posted : 25 May 2019 15:48:50(UTC)
Hics
You mean that it is possible to get through a MRR session...
What is MRR session?
You mean that it is possible to get through a MRR session without any F words? BigGrin
If MRR means anything to do with loco fixing and amending then no, no way. I'm swearing on myself "why did I do this or that?" and "this is the last time I'm doing this"
thanks 3 users liked this useful post by Hics
This page was generated in 0.419 seconds.
