Offline Hics
#1 Posted : 17 May 2019 12:48:43(UTC)
Hics
Hello.
My new item has just arrived. It is used 39370. Because of this I have two questions.
1. It has a c-sinus engine. And I have to say I'm a little disappointed about how noisy it is. As it only starts to spins it is more noisy then standard central engine. I oiled it a little bit but it didn't helped much. Is there any way to make it quieter?
2. Lights. It has directional yellowish LED in front and red and the back. But it also has a "long lights" (is it the right word?). But this one works in one direction only. If I change the direction this light stays and red lights appears next to it. It looks quite awkward. Does this mean that decoder is damaged?
[img]http://[/img]BR 101 decoder.jpgBR 101 engine.jpg
Offline applor
#2 Posted : 17 May 2019 13:07:29(UTC)
applor
Originally Posted by: Hics Go to Quoted Post
Hello.
They are a bit louder than modern DC motors but quieter than the older DCM. Nothing you can do about it
I haven't looked up the manual but from these style engines when I used to own them, the long distance headlights were individually activated for front and rear - they do not change direction like normal headlights.
Therefore if you change directions, you need to turn the long distance lights off for direction 1 and turn them on for direction 2. Try the next sequential function key ( F2 and F3 maybe?)
Offline lewistrain
#3 Posted : 17 May 2019 13:22:37(UTC)
lewistrain
Would you be able to describe the noise or post a video of it?.
Perhaps some foreign object has attached itself tp the permanent magnet inside the motor?
LOLOLOL they are just toys, grow up and play with them.
Offline Hics
#4 Posted : 17 May 2019 13:24:14(UTC)
Hics
I haven't looked up the manual but from these style engines when I used to own them, the long distance headlights were individually activated for front and rear.....)
I will try it tonight and I will let you know later does this work.
Offline Hics
#5 Posted : 17 May 2019 13:28:35(UTC)
Hics
I would love to do it. Can I upload a clip here?
But as applor said looks like this is ok. It is noiser than central engine but a little quieter then DCM
Offline franciscohg
#6 Posted : 17 May 2019 17:17:17(UTC)
franciscohg
Chile
Hi, here is a little video showing a Big C sine engine.
Hope it can be seen
https://m.facebook.com/s...=1171492085&sfnsn=mo
Offline Hics
#7 Posted : 17 May 2019 17:26:10(UTC)
Hics
Hope it can be seen
Thanks franciscohg
I have got sound to the max and I can hardly hear it. Mine c-sine is like a tractor compared to this one.
Offline franciscohg
#8 Posted : 17 May 2019 18:03:00(UTC)
franciscohg
Chile
I was surprised that you found the motor noisy, perhaps it is damaged.
All of my Big C sine motors runs great,
I made a video on a test stand
Offline Hics
#9 Posted : 17 May 2019 18:32:10(UTC)
Hics
wooooow!!!
wait when you hear mine. this will be like a tractor.
I wiĺl post it tonight.
thanks 2 users liked this useful post by Hics
#10 Posted : 17 May 2019 21:19:23(UTC)
From my C-sine grey Franco-Crosti, I remember it has a kind of "electric power plant" sound at the first 1-3 speed steps - but it runs fine and it is a great motor indeed.
Offline AshleyH
#11 Posted : 18 May 2019 08:49:18(UTC)
AshleyH
The 39370 had a very early C Sine motor. I think it was only the second model fitted with one, after the ICE-S Train, which was an evaluation model.
I no longer have one in my collection, but recall that is was slightly noisier than main production models such as 39573 and 39579 for some reason.
Also, I believe that a different function key operates the long or high beam headlights at each end, they are not directional.
Edited by user 18 May 2019 14:03:53(UTC)  | Reason: Not specified
Offline Hics
#12 Posted : 18 May 2019 12:58:10(UTC)
Hics
It is exactly what happens with mine
This is true as well. I discovered it yesterday. Listen them on loud speaker.
I did some video yesterday as well.
Check this one closer from 14th second.
And this one shows that as I lift loco noise stops but wheels carry on spinning. But then it is quiet.
Offline lewistrain
#13 Posted : 18 May 2019 21:34:45(UTC)
lewistrain
Wow that is quite odd.
It may not be the motor, remove the body again and turn the motor over by hand, it should feel very smooth with no obstructions, it should be very very easy.
Hopefully you will be able to feel something wrong or see where the noise is coming from.
Offline Hics
#14 Posted : 19 May 2019 00:18:49(UTC)
Hics
I have a feeling it is a vibration of a body. The engine itself runs very quiet. But as soon as I drop it on a track this noise appears. If I only lift it by 1 mm, loco will still run but noise disappears.
I'm thinking about some kind of foam between body and a buggy.
What could I do to reduce vibration? Buggy seats on 4 points of metal. If I for example paint them with some kind of "paint" which will leave a surface covered this should reduce the noise.
What do you think?
Offline dickinsonj
#15 Posted : 19 May 2019 15:08:01(UTC)
I have a feeling it is a vibration of a body. If I for example paint them with some kind of "paint" which will leave a surface covered this should reduce the noise.
What do you think?
I don't think that will fix your noise problem, but it might create a grounding problem from the chassis to the rails. I think that it could be a mechanical problem and if the motor spins as freely as it should, then I would suspect the culprit might be in the gear train.
Good luck and let us know what you learn.ThumpUp
Offline Hics
#16 Posted : 19 May 2019 17:34:43(UTC)
Hics
What do you think?
I didn't think about grounding but I think you are absolutely right. Im afraid I will have to live with it. I'm also starting to think it's a gearing problem. One of a wheels is a little lose. It is a tiny tiny but this can make this noise as it starts to spin.
Guest (11)
This page was generated in 0.434 seconds.
