Offline PeFu
#1 Posted : 14 May 2019 00:05:05(UTC)
PeFu
I’ve received my first ESU LokProgrammer, and I must say the software is very nice and user-friendly. I added a 2-pole alteration switch (On-Off-On), installed everything in the ”power cabinet”, and now I can use either the CS2 programming features or the ESU LokProgrammer without risking interference. Also, at ”Off” I have a power-free track when adding new trains to the layout. Me like! Cool
thanks 3 users liked this useful post by PeFu
Offline TEEWolf
#2 Posted : 14 May 2019 02:12:37(UTC)
Is it for programming only or is it as a decoder tester usable too?
Quite expensive for 150 €.
Offline applor
#3 Posted : 14 May 2019 06:09:27(UTC)
applor
Great idea! I wish I had a fixed programming track that connected to my layout for programming and to add/remove trains. I am not sure I can do it anymore.
Yes it lets you test all ESU decoders (including servos). Only limiting factor is protocol support is DCC and motorola, it can't test M4/MFX (you have to test with motorola), probably due to how M4 works.
Offline PeFu
#4 Posted : 14 May 2019 06:34:27(UTC)
PeFu
Well it’s pretty advanced, a bit of a ”central station” as you both can program and test decoders. You can program all DCC decoders, including the DCC part of Märklin decoders. For other Märklin decoders, it’s nice to have the CS2 programming features. ESU LokProgrammer can also add downloaded sound files to ESU decoders. The below clip gives an overview (The testing features starts at 4 min 20 sec):
#5 Posted : 14 May 2019 07:02:31(UTC)
It's a great kit Cool
Offline Gregor
#6 Posted : 14 May 2019 08:46:50(UTC)
Gregor
I am installing a rotary switch to connect the programming track alternatively to:
1. Intellibox normal track
2. Intellibox programming track
3. ESU Lokprogrammer
4. Märklin Mobile Station
My programming track is a separate roller bed and a dedicated section on the layout, so I can program trains without taking them off the track.
When rotary switch is not in Position 1, power to the rest of the layout (controlled by Intellibox) is shut down. This prevents a train from driving unintentionally from into the programming track, thus connecting the outputs from two differente control systems.
Gregor
This page was generated in 0.306 seconds.
