#1 Posted : 10 May 2019 09:30:41(UTC)
Suddenly my signal LEDs did stop shining but the decoder still work and switching too.
I did checked in the configuration and value stand full shining.
LEDs default?
#2 Posted : 10 May 2019 11:22:01(UTC)
What's the voltage rating for your signal, or what type is it?
#3 Posted : 10 May 2019 17:21:21(UTC)
19 VDC from the CS3.
Signal is a mfx 76491.
#4 Posted : 10 May 2019 18:35:19(UTC)
I think a good plan would be to measure the voltage of the output going to the LEDs................. Cool
#5 Posted : 10 May 2019 23:32:20(UTC)
The LEDs are broken.
A € 75,00 kaputt!!
Edited by user 13 May 2019 19:29:46(UTC)  | Reason: Not specified
#6 Posted : 11 May 2019 04:28:54(UTC)
nothing works for you, is your house running 380V three phase power maybe?
#7 Posted : 11 May 2019 07:59:40(UTC)
I found the problem.
It was bad soldering by Märklin.
The two wires white and the pink was poorly connected to the circuit board.
#8 Posted : 11 May 2019 08:02:35(UTC)
And you have no good cooperation by write sensible comment?
Confused
Offline Bones
#9 Posted : 11 May 2019 13:08:32(UTC)
Bones
Glad to hear you solved the problem
#10 Posted : 13 May 2019 19:29:22(UTC)
Now this time the signal is dead.
The decoder stop working and no respons.
Strange...i did fixed the problem about LEDs but now decoder failure.
I did used digital signal in two years and it costed about €75,00.
#11 Posted : 16 May 2019 07:03:51(UTC)
Did fixed the problem and it works again.
#12 Posted : 16 May 2019 17:18:29(UTC)
Oh, what was the problem this time, or did you have to replace something?
#13 Posted : 16 May 2019 19:56:51(UTC)
Poor wires and this time add end terminals.
This page was generated in 0.606 seconds.
