Offline danmarklinman
#1 Posted : 02 May 2019 23:37:16(UTC)
danmarklinman
I’ve just found these two items, but there’s very little on them, such as minimum radius. These look much more of a simple design unlike the very complicated Marklin TGV sets. But they may just have DC wheel sets and a slider with the problems of gauge as these wheel sets may have problems over K track points?
http://www.gaugemaster.c...mp;OB=&currentpage=1
I’m interested in finding more about them, if anyone knows.
Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 02 May 2019 23:42:11(UTC)
I have a whole bunch of Jouef wagons that work fine on my C-track layout. I have not needed to change the wheelsets.
Offline mmervine
#3 Posted : 03 May 2019 02:54:49(UTC)
mmervine
These are improved models based off of the Lima TGV (new generation) molds from 1990's. I would guess that you are correct that they have DC wheels with a slider.
I have converted many of the original Lima TGV (new generation) versions by adding a Marklin slider. Lima originally offered a few of these in AC versions and the front boogie has provisions for adding a slider. I used either a Lokpilot or Loksound for the driving car (M1) and a Lokpilot FX to switch the lights in the false driving car (M2). I also added some weight to each of the center cars (R1-R8).
I can't speak to K track, but I have not had any issues operating these on C track. The end cars (R1/R8) are longer than the middle cars (R2-R7) and will look and operate best on R2 or greater.
r/mark
thanks 1 user liked this useful post by mmervine
#4 Posted : 03 May 2019 07:15:11(UTC)
I bought the Lima Expert RABe 503 (ETR 610) and had it converted by the dealer. I took a look at the interior and I was not impressed by the design of the circuits and electronics.
I bought the twin set of Rivarossi BLS Re 4/4s a few years back and one of them had a short between the decoder and the circuit board, which I fixed.
I don't know how reliable these models are in long term use, as I have not used mine very much.
https://www.hornby.com/u...vi-ac-digital-sound.html
I could not find any information as to whether the model will have current conducting couplers, optional interior lights and power selection from the leading power unit.
#5 Posted : 03 May 2019 09:20:41(UTC)
danmarklinman
It all looks a bit vague from Hornby. I will need to see them running.?before I make up my mind.
Do your BLS ac locos run ok? Since Jouef and Riverossi are all designed by the same people. Thanks Dan
Wiking fan
#6 Posted : 03 May 2019 09:24:01(UTC)
danmarklinman
Thanks Ray. Yes the wagons I know will be fine. But the power car might not. I might just weight for a Marklin one. Unfortunately I can’t make up s five car set, just a four or a six.
Wiking fan
Offline IanC
#7 Posted : 03 May 2019 12:14:39(UTC)
IanC
Hi Dan,
I notice Rivarossi are doing the Big Boy. It would probably be worth them doing a 3 rail ac version too.
We must get together again with Max for a pint at the Railway Inn sometime.
Best wishes
ianC
thanks 1 user liked this useful post by IanC
#8 Posted : 03 May 2019 12:44:30(UTC)
danmarklinman
Originally Posted by: IanC Go to Quoted Post
Hi Dan,
Best wishes
ianC
Yes of course, or at my house👍
Wiking fan
#9 Posted : 03 May 2019 17:19:45(UTC)
Thanks Dan
I set up and ran the ETR 610 for a few laps on my oval. The same for the Rivarossi BLS Re 4/4 set.
The BLS brownies were from the second batch. The first being the single lok with the crest of "Grenchen". The twin set was then released with one BLS and one BN Lok. The two are designed to be used as a multiple unit. In order to use the loks independently, you have to change dip pins on the PC board.
Seeing that the loks (AC) are equipped with ESU decoders, the light settings could have been left to the decoder and made the circuit board changes unnecessary.
Mechanically, they run fine.
The newly released models are supposed to be improvements over the earlier models.
I have since bought the two new Roco models, so those will handle the individual operations and the Rivarossi set will run as a pair.
Compared to LSM, Roco, Maerklin and other brands, the Hornby models seem rather "rough" in electronic conception. The PC boards are not as clean and don't seem to be as modern. As far as exterior fit and finish, they look fine.
#10 Posted : 03 May 2019 17:44:08(UTC)
danmarklinman
Thanks Dan
Thanks Mike. Is that c track your using of K? And do the run through points ok. Dan
Wiking fan
This page was generated in 0.386 seconds.
