Offline PeFu
#1 Posted : 02 May 2019 21:59:20(UTC)
PeFu
In March, I purchased a Märklin Booster 60174 and Märklin Trafo 60052. Testing on a 3rd rail isolated track section, I have problems according to the below clip:
https://www.dropbox.com/...5-02%2018.12.46.mov?dl=0
Trains on the CS2 track section are fine. According to the CS2, temperature of the Booster is pretty high (approx. 25C), voltage high (23-24V) but the load is low. After approx. 10 minutes, the CS2 crashes, everything is dead. I have tested several times with the same result, even with using a Märklin Trafo 6002 instead of the 60052. Both transformer outputs are approx. 16-17 volt.
I believe the Booster is broken, and the seller has offered a return. However, I’m curios to learn if someone else has experienced something similar?
Confused
Offline French_Fabrice
#2 Posted : 02 May 2019 22:25:21(UTC)
French_Fabrice
Hmm,
I'm not sure transfo 60052 is well suited for a booster. Do you have previous successful experience with such combination ?
I would suggest to put a 60061 instead, just to be sure the booster has a problem or not.
25°C as temperature is normal; 23-24V is NOT normal -> you should have a value between 18 & 19V.
Voltage stabilization issue ?
Fabrice
Offline PeFu
#3 Posted : 02 May 2019 23:17:52(UTC)
PeFu
Hmm,
It’s the first time I test a booster since the 6021 era... According to page 7 of the manual...
https://static.maerklin....15a61070441434542313.pdf
...a 60052 should be fine. Also, I have tested the whole booster track section, that there is no leakage from the CS2 booster.
#4 Posted : 03 May 2019 09:19:28(UTC)
Voltages above 20 V are expected when using 16 V AC on the input side of the booster.
The value should be below 19 V when using 19 V DC on the input side.
I'd try using the same type of power (AC or DC) for both CS and booster to avoid potential problems.
Offline PeFu
#5 Posted : 14 May 2019 21:59:18(UTC)
PeFu
Just an update on this. I returned my products to the seller, and purchased a new 60175 booster and a 60041 power package. Everything is now working perfect! I guess I will never learn if the problem was with the 60052 transformer providing to much voltage, or the 60174 booster.
B.t.w., I’m impressed by how little Amps the trains consume!
#6 Posted : 15 May 2019 13:23:18(UTC)
Hi PeFu
Yes indeed My layout with 31 locos 25/30 illuminated cars needs 2.7 amps
Power is provided by 60101 and CS2 60215
Guest (4)
This page was generated in 0.349 seconds.
