Offline Rocca
#1 Posted : 03 April 2019 10:57:26(UTC)
Rocca
Dearest Märklin friends,
Do you think that it would be safe to use the digital loco 2680 (in a fully digital system with a 6021) with the coaches coming from the 2880 Set, which means with an analogue set? May i do that? Or eventually may I mix digital and analogue coaches.
Any advice is very appreciated!
Stefano
Offline franciscohg
#2 Posted : 03 April 2019 13:08:31(UTC)
franciscohg
Chile
Hello, it should be no problem at all.
Coaches are fed trough the loco and equipped with bulbs and no other electronics (flickering lights you will have)
Offline Rocca
#3 Posted : 10 April 2019 23:23:50(UTC)
Rocca
Hello, thanks! do you suppose the flickering will damage the lamps or not? Is not the voltage in the Digital system very higher than in the analogue? May all work right anyway? thanks in advance for any suggestion! Beste regards
Stefano Rocca
Offline franciscohg
#4 Posted : 11 April 2019 04:08:14(UTC)
franciscohg
Chile
Hi, more than the flickering lamps in the analog version could be affected by the slightly higher voltage leading to premature dead of the bulbs. Also with too much time of ooperation they may free too much heat damaging the plastic. I would use them not for very long time and replace them later for proper digital bulbs. But it should be no problem using it to watch your train run.
Offline Ross
#5 Posted : 11 April 2019 05:50:21(UTC)
Ross
Hi Stefano,
You may be interested how I upgraded my train to LED lights see link below.
2680 Article
Don't use analogue coaches with digital control unless you change to bulbs suitable for the higher digital voltage. In the article I show you why, see page 12 for current details.
I hope you find the information useful.
Stefano
Ross
This page was generated in 0.241 seconds.
