Offline jcrtrains
#1 Posted : 19 March 2019 02:46:49(UTC)
jcrtrains
Folks;
Has anyone found that different manufacturers wheels on carriages build up gunk at very different rates? I just went through one manufacturers carriages and found enormous buildups. Looking through a sample of a different manufacturers of carriages a similar age and usage and I see clean shiny wheels. Anyone see anything similar?
#2 Posted : 19 March 2019 03:53:02(UTC)
it could be said earlier wagons wheels may have contributed to the build up of muck and grime, its just a theory
#3 Posted : 20 March 2019 14:01:47(UTC)
Interesting idea!
I have rolling stock from many different brands, but havent seen any "preferrence" for gunk build-up by brand.
But you might be on to something, as I do seem to have a build-up depending on wheel-type. (I´m thinking kind of metal/alloy here)
I havent examined the issue systematically, but some waggons definetly have more gunk than others! -I find myself cleaning the same few waggons most often.
Additionally I wonder if the rate of the build-up could be proportional to the amount of contact-tracks used for feed-back¿?
Offline TimProdigy
#4 Posted : 20 March 2019 19:16:34(UTC)
TimProdigy
"it could be said earlier wagons wheels may have contributed to the build up of muck and grime, its just a theory"
Now, I'm actually curious as to how this would happen.
#5 Posted : 21 March 2019 08:03:01(UTC)
The profile of wheelsets can vary from manufacturer to manufacturer. Some make more contact with the rails than others. I also think that there may be some difference in the type of metal used by different brands that could have an effect. I also wonder whether the fact that the wheelsets may or may not be used to conduct the ground (return) or to bridge contact between the rails may also have some impact on whether the wheels attract dirt more than others.
#6 Posted : 21 March 2019 08:07:40(UTC)
In the days when I ran a lot of 2 rail US prototype with plastic (or delrin) wheels, the gunk would build up regularly.
It did not build up when I changed to metal wheels.
Offline DTaylor91
#7 Posted : 21 March 2019 20:45:52(UTC)
DTaylor91
The worst brand ever with this problem: Lionel during the postwar period - 1945 - 1969!!!!
I suspect a combination of carpet fuzz, too much oil, and smoke fluid residue to be at fault.
Offline HO Collector
#8 Posted : 21 March 2019 22:29:33(UTC)
HO Collector
When I was a kid (early 60's) I used to run my trains on the floor tiles. I had to clean the wheels on a regular basis, engines and wagons, the muck was removed with a flat head screw driver. However, I have never had to clean the tracks using any abrasive material (never thought about any of the great deigns that you guys came up with, see the cleaning track discussion). A dumped cloth with kerosene did the trick and even this was a rare occasion.
Ben
This page was generated in 0.498 seconds.
