Offline LongHairedDavid
#1 Posted : 04 March 2019 13:40:46(UTC)
LongHairedDavid
Hello.
I am thinking about buying either a CS3, and ECOS or a 2nd hand CS2. Budget isn't an issue.
CS3 would come from Germany, 2nd hand CS2 from the UK or new ECOS 1 mile down the road from Coastal DCC.
One thing I don't know is, will my existing Mobile Station connect to an ECOS and give me three controllers?
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
#2 Posted : 04 March 2019 14:01:45(UTC)
Yes, the MS2 can be connected to the sniffer port of the ECoS with the MS2 trackbox in between.
The bi-directional CAN bus connection of the CS2/CS3 has some advantages.
OTOH the sniffer port connection also has advantages if you use the MS2 for visitors or children.
#3 Posted : 04 March 2019 15:48:55(UTC)
Hi David. I always buy Marklin but if you can get an ECOS a mile from you then at least you have back up and can hand it back if not working.
Watch for the price though compared with your Lippe account.
#4 Posted : 04 March 2019 17:02:34(UTC)
LongHairedDavid
I have had my big discount this year so £630 for an ECOS is fine.
I live very close to Coastal DCC. Before Kevin had a shop, it was great because I could pop in after work!
He really knows what he is doing and is a nice chap so I will probably go down that route.
Long Haired David
Offline TEEWolf
#5 Posted : 04 March 2019 18:40:31(UTC)
Hello.
An ECoS cannot use the mfx+ format and with an ECoS you are not able to update the software of your MS 2. Finally I do not think that you can get the very use- and helpful CAN bus with an ECoS too.
If somebody has already a Märklin controller, my recommendation will be to stay with Märklin controllers.
#6 Posted : 04 March 2019 18:52:21(UTC)
Can you please explain what you mean by this?
Offline TEEWolf
#7 Posted : 04 March 2019 18:54:57(UTC)
Here is a CS 3 for 534,48 € and power supply for 60061 61,90 €
https://www.besserepreis...-mae&portal=94511215
https://www.besserepreis...=9999999&language=de
Together 604,38 € was today converted to Pounds 519,20.
All rigth you can pay 630 Pounds for an ECoS, but here in the forum you have more specalists for a CS 2/3 than for an ECoS, because this is a forum named "Märklin-users.net".Blink BigGrin
#8 Posted : 04 March 2019 23:30:04(UTC)
It will be more convenient but its not Marklin and I presume the shop does not sell Marklin products. Pity you used your discount on something that did not save you cash after paying the Premium membership.
#9 Posted : 05 March 2019 00:20:35(UTC)
Hello.
If budget isn't an issue then go straight for a cs3. The cs2 will reach the point where it cannot be upgraded sooner than the cs3 will, and the cs3 is also faster to boot up and when operating processes things faster as it has a much better processor chip.
I don't think the Ecos has the data base of non-mfx locos that the cs2 and cs3 have, and also will not get updated with newer non-mfx items as time goes by. This means you will need to enter all the functions when setting up a new loco, where with a marklin controller you call up the loco by catalog number from the database and it is all set up ready for you.
If you already have an ms2 then either a cs2 or cs3 will accept it as an additional throttle. There are limitations to what it can do as it only has access to 16 functions, so items with more functions will not be able to use the higher function numbers from the ms2.
#10 Posted : 05 March 2019 07:10:47(UTC)
Hello.
if you talk about a Mobile station 1 yes you can directly connected it to the ECoS (4) all you need is an adapter cable and if I'm correct, (most the time not) the number of locos increased beyond 80 but I can't say if this is the fact , the 6021 will and also allows you to have 16 aux functions with 4 different decoder numbers
Offline ktsolias
#11 Posted : 05 March 2019 08:36:37(UTC)
ktsolias
Go straight for a CS3
The compatibility with Marklin decoders is better than Ecos (with programming tools 60971, mDT3, )
If you want to use ESU decoders then may be Ecos is a choice
Costas
This page was generated in 0.477 seconds.
