Offline ocram63_uk
#1 Posted : 27 February 2019 18:04:10(UTC)
ocram63_uk
Good afternoon everyone, I was running two engines with my ECoS. One mount an ESU Lokpilot and the other a Motorola where I have applied the chokes. This loco is a retrofitted 3035
To avoid a collision I pressed the STOP button.
When I powered back the track the Esu loco resumed exactly where it left off.
The 3035's light started flickering and all of a sudden it shot down the track. It never came back to life.
I tried reading the decoder, it fails reading it.
I used the reset code on CV8 but nothing changed. Only one light bulb lights up and is always on.
Is the decoder really dead ? I believe so Cursing
Never had this happen to me before
Has anybody else witnessed this type of behaviour
Offline TEEWolf
#2 Posted : 27 February 2019 19:50:23(UTC)
Well, if the decoder is really dead, do you think that still a ligth would burn?
#3 Posted : 27 February 2019 20:10:08(UTC)
Why not? A transistor can fail either as open or as a short.
Heat not removed burns up the semiconductor junction (open,) while surges will weld it (short.)
Offline TEEWolf
#4 Posted : 27 February 2019 20:15:31(UTC)
Per.Cool
I never tested it and I also do not want to test it, too expensive. But by logic, if a decoder is "really dead", how shall it still supply any consumer with power? We do not talk about a transistor etc., we talk about a complete and really dead decoder.Cool
#5 Posted : 27 February 2019 20:26:41(UTC)
The "thing" that turns power on or off in a decoder, is a transistor. BigGrin
It can be inside an integrated circuit; but it's still a transistor.
You are surely a nice person who tries to help; but just as surely you have no idea how electrical or electronic circuits work. Blink
#6 Posted : 27 February 2019 20:27:18(UTC)
Per.Cool
Don't get hung up on 'dead' - "Failed" would be a more accurate word in this context even though 'dead' also covers it quite well.
The decoder appears to have failed, internal damage has left it in an undetermined state where it no longer responds to commands but some internal circuits are permanently altered/damaged with one symptom being the continuous light glowing.
ie - "The lights are on but nobody is home" BigGrin
Edited by user 28 February 2019 08:57:24(UTC)  | Reason: Not specified
Guest (4)
This page was generated in 0.258 seconds.
