Offline Thewolf
#1 Posted : 27 February 2019 16:20:28(UTC)
Thewolf
Hi guys Cool
A question please : which wire cross-section between the cs2 or a booster and an M84-M83? 0.75 mm2 or 0.14 mm2?
I would opt for the 0.75mm2
Thank you
Thewolf
Offline TEEWolf
#2 Posted : 27 February 2019 20:11:28(UTC)
Hi guys Cool
Thank you
Thewolf
0,75 mm² are good. I use the same profile. Märklin requests as a minimum 0,5 mm² cross-section between a CS and the layout current feeding point.
A booster and/or a m83/m84 is part of the CAN-bus. Either they do have their own power supply (like the booster) or get their power via the CAN-bus. But they have always their own special cabel for the CAN-bus conncetion. Another special extra wiring is not required between the devcies. For cabeling between a device (e.g. m83) and a turnout a profil of 0,14 mm² will be sufficient by Märklin.
Offline Thewolf
#3 Posted : 27 February 2019 20:22:54(UTC)
Thewolf
Hi guys Cool
Thank you
Thewolf
Thank you TEEWolf
I will choose the 0.75 mm2 from my booster because I will have a series of M84 and M83 coupled together and an additional reason for this choice is that an output of an M84 will allow the lights of the city to go out.
Good afternoon
Thewolf
This page was generated in 0.224 seconds.
