Offline John N
#1 Posted : 15 February 2019 03:04:26(UTC)
John N
I have a MS3 plus controller which operates the mfx locos I have perfectly on a simple loop test track. I placed a loco 3473 (Delta) on the test track on its own with the controller speed set as zero . The engine immediately roars off at top speed with no control using the MS3 plus controller. Can anyone suggest a solution to obtain control? Cheers
Offline Markus Schild
#2 Posted : 15 February 2019 07:20:52(UTC)
Markus Schild
Hi John,
Welcome to the forum.
The 3473 has a decoder without automatic recognition of the operation mode. It has a small dip-switch on the decoder. When all the switches are in "off" position it is in conventional-AC-operation mode. This will show the effect you describe. Open the body of the loco and check the dip-switches. Google with "märklin delta adressen" finds the tables with settings for the dip-switches.
Markus
Offline John N
#3 Posted : 15 February 2019 10:13:35(UTC)
John N
Hi Marcus
I shall check them out. Thanks for the prompt reply. Cheers John N
Offline John N
#4 Posted : 27 February 2019 09:41:19(UTC)
John N
That worked, Loco now operates as it should. Thanks for your assistance, Appreciated. John N
This page was generated in 0.354 seconds.
