#1 Posted : 14 February 2019 21:46:03(UTC)
I just downloaded the CS2 Update 4.2.8 (4) and this thread is about sharing the identified new functionalities.
I hope my forum friends will find loads of new things (more than I have BigGrin ).
What I have found (not much sorry)
A new staging yard functionality: it designs them for you with dialogue for points and signals
A new line section assistant (entry signal, exit signal, sensors
A new function to insert the image of any loco in the layout (I must say I haven't found the principle. I checked if it was some sort of location assignment of locos (like on train s/w) but I couldn't find the purpose. (it is not in the help screen)
"World of operation" is now available for any loco with any decoder- the restriction is there is no consummable management and you may choose for the loco the appropriate or closest driving environment
Probably you will find much more than this
#2 Posted : 14 February 2019 23:12:08(UTC)
Deleted - post for CS3 not CS2
Edited by user 15 February 2019 03:19:16(UTC)  | Reason: Not specified
#3 Posted : 15 February 2019 03:25:23(UTC)
It may be of assistence if a collegue could translate ...
Essentially
"B" is a block section and you must drag an area that is only one cell wide and a minim of 6 cells long (either vertically or horizontally)
"S" is a staging/Schattenbahnhof and you must drag at an area at least 2 wide (i.e. number of roads)
Offline Elsleuth1
#4 Posted : 15 February 2019 03:40:42(UTC)
Elsleuth1
One website said the changes are:
1. Extension of the possibility with appropriate locomotive decoders to switch up to 32 functions instead of 16 functions so far.
2. Complement the Spielewelt Mode with new driver's guides.
3. Aligning certain operating behavior with the processes at CS 3.
#5 Posted : 15 February 2019 11:27:15(UTC)
Essentially
B is a Block section and on the screen you must define a rectangular zone of 1 by X (any length) or X by 1 to define an horizontal or vertical block
S is a staging yard and on the screen you must define a rectangular zone of X (length) by Y (number of tracks)
The points, signals, sensors are proposed (must correct their addresses) and the functioning is either FIFO or random
#6 Posted : 15 February 2019 14:00:47(UTC)
Here is the separate technical note on the new changes on update 4.2.8 (4)
http://streaming.maerkli...update_4_2_8_info-02.pdf
Alas nothing on the new stageyard and block functions
#7 Posted : 15 February 2019 14:18:33(UTC)
Sie muessen einen (rechteckigen) Bereich fuer "the block section" auswaehlen:
You have to select a (rectangular) area for the block section.
Sie muessen einen groesseren Bereich fuer den Schattenbahnhof auswaehlen:
You have to select a larger area for the shadow station.
Sie muessen einen Bereich mit Hoehe = 1 und Breite >=5 oder mit Breite = 1 und Hohe >= 5 fuer die Blockstrecke auswaehlen:
You have to select a block section area with a height of 1 and a width of 5 or more [units] or alternatively with a width of 1 and a height of 5 or more [units].
#8 Posted : 17 February 2019 04:24:08(UTC)
Those comments relate to the earlier v4.2 (4.2.2) - The CS2 has had support for 32 functions for over a year.
For this recent update v4.2.8 a changelog for 4.2.7 is seen.
Googly translation really struggles with this , so again I ask for some translation
GUI Version 4.2.7 (ab Herbst 2018)
- Für jede Lokomotive, egal welcher Decoder oder Protokoll, kann die Spielewelt verwendet werden. Da ein nicht Spielewelt-Decoder keine Verbrauchsberechnung macht, ist diese bei diesen Loks deaktiviert. Tanken und Verbrauchsanzeige ist somit nicht möglich.
- Bug Fix: Korrektur Drehscheibenassistent. Eine Platzierung nahe am Rand ist nun möglich
- Anmelden neuerer Decoder. Beim Anmelden neuer Decoder wurden diese versehentlich als Spieleweltdecoder interpretiert und entsprechend falsch behandelt. Die Anmeldung wurde dem robusteren Verfahren der CS3 angeglichen, neue Decodergenerationen werden nun korrekt angemeldet.
Offline French_Fabrice
#9 Posted : 17 February 2019 07:35:49(UTC)
French_Fabrice
Translation provided by DeepL:
GUI version 4.2.7 (from autumn 2018)
- For each locomotive, no matter which decoder or protocol, the game world can be used. Since a non game world decoder does not calculate the consumption, it is deactivated for these locomotives. Refuelling and fuel consumption display is therefore not possible.
- Bug Fix: Correction turntable assistant. A placement close to the edge is now possible.
- Register newer decoders. When registering new decoders, these were accidentally interpreted as game world decoders and treated incorrectly. The login has been adapted to the more robust procedure of CS3, new decoder generations are now correctly logged in.
A German speaker may validate if translation is correct.
Fabrice
thanks 2 users liked this useful post by French_Fabrice
#10 Posted : 17 February 2019 09:52:55(UTC)
This Block/Staging function set (and the loco image) has got to be a Beta that leaked out.
Aside from the lack of English in the messages, the icons are too easily corrupted and the sensors have the same 1024 limitation for L88s.
#11 Posted : 17 February 2019 12:49:39(UTC)
Translation provided by DeepL:...A German speaker may validate if translation is correct.
Pick me, pick me: Certified clean, I mean correct.
:o)
#12 Posted : 18 February 2019 02:57:11(UTC)
Marklin are offering three quarters support for MPH
might be a Brexit thing Bored
The other new icon set ...
I am guessing this has something to do with the braking or block macro.
#13 Posted : 18 February 2019 15:33:12(UTC)
Even though nobody asked for a translation this time, I allowed myself to carry on:
Im markierten Bereich befinden sich Elemente fuer Automatik-Steuerung. Sollen diese entfernt werden?
There are elements for automatic control in the marked area. Do you want to remove them?
Mit dieser Aenderung wird die Automatik-Stuerung entfernt. Moechten Sie fortfahren?
This change removes the automatic control. Do you want to continue?
Offline Thewolf
#14 Posted : 20 February 2019 23:14:45(UTC)
Thewolf
Hi guys Cool
During the update 4.2.8 which was done twice and followed by a restart of the cs2, at one point 5, if my memories are good in point 5, I saw USB Import.
To complete the update, does this mean that I need to connect a USB key to the cs2?
Thank you
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#15 Posted : 21 February 2019 11:09:42(UTC)
No an online update does not need any USB update.
Offline Thewolf
#16 Posted : 21 February 2019 15:04:42(UTC)
Thewolf
Thank you Cool
But I did something this morning: the update was deemed a success yesterday (the message on the cs2 showed this).
This morning I made an attempt to update to see what.
Point 5 of yesterday's update has restarted, as if the update had not been completed.
Does anyone have any ideas?
Thewolf
#17 Posted : 21 February 2019 15:58:28(UTC)
Could it be that No. 5 is the "Evergreen" update? As the name implies (at least to those with a good German knowledge), it is executed every time and tries to upload new loco images from the USB stick.
Ignore this feature of Märklin's clear-as-mud UI design.
Offline Thewolf
#18 Posted : 21 February 2019 16:08:58(UTC)
Thewolf
Thank you Cool
This page was generated in 0.784 seconds.
