Offline Hics
#1 Posted : 13 February 2019 17:01:55(UTC)
Hics
I was just told that height of rails used in Start UP sets is 2.3 mm while standard height of C Gleiss is 2.1 mm. Is that true?
#2 Posted : 13 February 2019 17:29:22(UTC)
Could that be for the plastic tracks that come with the battery powered sets?
Offline Hics
#3 Posted : 13 February 2019 17:33:53(UTC)
Hics
Exactly. I'm just arguing with someone who claims 2.3 mm are being used in Start UP sets but I think he is wrong. But if 2.3 are in My World they are not good for us to use anyway. I think he is wrong.
#4 Posted : 14 February 2019 00:39:55(UTC)
Märklin C track uses rails with 2.3 mm height, Trix C track uses rails that are 2.1 mm in height.
Rails have the same height - starter set or regular sale.
So the statement is sort of true - but it is not the full truth.
I don't know which height you find in current My World sets. But you can use them with both Märklin C track and Trix C track (but trains won't get power as the rails are plastic).
Offline TEEWolf
#5 Posted : 14 February 2019 02:38:58(UTC)
Some measurements about the C-track and clearances.
http://www.modellbahnkel...astelstube/Lichtraum.htm
NEM 340 about Märklin centerrails tracks
https://www.morop.org/do...oads/nem/de/nem340_d.pdf
As you see the elevation of a C-track is 2,3 mm.
#6 Posted : 14 February 2019 07:46:47(UTC)
I have C track with a height of 2.1 mm, too. Their rails are nickel silver, not stainless steel.
As you see there are two different rail heights for C track.
Offline mbarreto
#7 Posted : 14 February 2019 09:46:09(UTC)
mbarreto
Do you refer only to 3-rails C track or are you considering the 2 rails and 3 rails C track?
About the material, judging by the color, I thought 2 rails C track was/is nickel silver and 3 rails was/is stainless steel. But was just a guess...
Miguel
Miguel
Mostly Märklin H0.
#8 Posted : 14 February 2019 10:43:21(UTC)
We have a question in "General MRR" that does not mention Märklin or Trix, so my answer covers both types of C track.
Maybe the existence of both Märklin C track and Trix C track with different heights was the cause of the question.
Offline Hics
#9 Posted : 14 February 2019 11:23:13(UTC)
Hics
Ok guys.
I have got what I wanted.
Let's end the discussion now.
thanks 1 user liked this useful post by Hics
This page was generated in 0.513 seconds.
