Offline John Ferguson
#1 Posted : 11 February 2019 19:48:04(UTC)
John Ferguson
The problem I have is that where I have used a track sensor to trigger the reduced speed for a train under automatic control, another train manually controlled passing over the same sensor will cause the automatic train to run again.
It appears that the track sensor is not solely reserved for the train under automatic control.
Can I have some help please to solve this problem.
Offline MaerklinLife
#2 Posted : 11 February 2019 22:27:36(UTC)
MaerklinLife
Correct. A sensor is a sensor, it does not care what activates it. If it is activated, the CS will perform what ever event you assigned the sensor to. If that means stopping a particular train, that will happen, no matter what activates the sensor.
It is by design and you can't really do anything about it.
If you have a CS3 you can limit the problem. On the CS3 you can check if the train you want to slow down is actually moving, and then only if that is the case, you can slow the train down. That way the train will not begin to move, unless it is moving in the first place.
It does not change that the event will be triggered by what ever activates the sensor. But it does prevent the train from moving if it is stopped.
#3 Posted : 12 February 2019 03:15:17(UTC)
..... A sensor is a sensor, it does not care what activates it.
True
If it is activated, the CS will perform what ever event you assigned the sensor to. ....
Partial true.
When a sensor i triggered, the CS will check for events that are configured to use that sensor AND whether they have an enabled condition
The CS2 memory allowed for multiple conditions, The CS3 only one
However the CS3 has internal logic that the CS2 does not (one step forward 2 steps back)
Not true.
I believe that once you appreciate that a Sensor is not directly and uniquely linked to the running of any single event, you may conceive numerous ways to replicate a true block system whereby a) a sensor is active Yes/No and b) which mode your environment is in (which loco is in a block), in order to direct specific instructions to specific situations.
To aid this you may even switch the sensor, via a relay, to different sensor ports.
I am not saying this is trivial, however there is a degree of complexity that can be managed at this level before you feel forced to jump to using a PC for its more elaborate layout tracking and control.
The new CS3 logic functions are helpful (in over coming external relay control of S88 ports).
What I was hoping for was a register pool to allow loading and tracking of a locomotive in a dynamic way.
#4 Posted : 12 February 2019 04:19:12(UTC)
MaerklinLife
Partial true.
No, true. As I wrote, although I did specify any condition. The sensor might as well be set to a diabled condition, it will still be the trigger of the event, except this time when the train leaves. The same goes: It does not matter which train it is.
Not true.
Yes, true. I don’t agree with my statement being “not true”. While it is true that you can take measures to TRY and prevent, there is no way that you can design a set of events that can not some how be confused by a rogue train doing something that was not intended. That is what I meant, feedback works by either there is something on the track or not. Even the computer guesses the position of the trains on the basis of a know origin and movements.
If you want to be able to drive around manually amongst your automatic trains, you are in for a challenge.
Only systems like Railcom can give you true positions of the trains. Sadly that is not an option with the CS3.
#5 Posted : 12 February 2019 05:10:34(UTC)
Partial true.
I do not understand what you are saying.
I am referring to the Event condition (Ok "Control") of the trigger, not a condition that may be set as part of the action string within that events definition.
#6 Posted : 12 February 2019 06:16:16(UTC)
MaerklinLife
I was referring to the "Position" setting of the screenshot that you show. Of course, you can set control contacts that will prevent triggering the event if these conditions are not meat. I do that myself, it works very well, and, true, it can help trying to prevent things from happening.
My point was: At the end of the day, it does not change the fact that the CS does not know what train passes over a sensor. It is the way the system is designed. And - currently anyway - there is no way to change that. Yes, there are work arounds, but they will never completely prevent weird things from happening if you grap a train and blast around the layout manually.
That being said, we might be in for something interesting in the future. The new version of the CS3 contains a feature to set the state of a contact (or other article) to be the location of a train. Currently limited to showing a trains location on the track plan. I imagine that it could be expanded on to have events triggered by a contact being set, and depending on which train it is set to contain, can perform something with that train - otherwise not. Anyway, new features, new options. It will be interesting to follow.
#7 Posted : 12 February 2019 09:34:44(UTC)
John Ferguson
Thank you both for your comments. It has enabled me to understand more clearly what is going on.
I will abandon the idea of mixing automatic and manual control for the time being.
Bearing in mind that more than one train will be passing a sensor I will try a trigger for each train on that sensor and look into control of the trigger.
#8 Posted : 12 February 2019 18:10:13(UTC)
John Ferguson
In your view of the screen you show what appears to be 2 sensors K1 and K3 where I can only put one sensor. Can you explain how you achieve this please?
#9 Posted : 22 March 2019 16:47:28(UTC)
John Ferguson
I will still very much want to know how you are using a control contact. It looks very useful.
By the way I have a solution to the problem of events sharing a sensor. For the second event I introduce a sensor in the event set to condition and delay. In the event that the sensor is not occupied processing of the event is stopped.. Resuming occupation allows the process to continue.
#10 Posted : 21 April 2019 20:43:39(UTC)
John Ferguson
The solution I have adopted to prevent a train being disturbed by a following train crossing a sensor set for the first train.
I use the if then else macro.
It starts with the sensor in the automatic position at the start of the event then a track sensor (the if) to follow is set to condition delay followed by zero speed (then) and then followed by the speed required (else).
The first train meeting the first sensor allows the second sensor (if) to be checked for occupation. If not occupied the zero speed (then) is ignored and the speed is selected (else).
The second train meeting the first sensor again allows the second sensor (if) to be checked for occupation. If occupied zero speed is selected (then) and the speed is ignored (else). Selecting zero speed of the first train is fine as it is already stationary.
I am using this approach many times on the layout.
#11 Posted : 03 May 2019 18:56:35(UTC)
John Ferguson
My latest solution for trains sharing a track sensor in automatic mode.
I set two or more turnouts following separate sensors used by more than one train to match routes previously set followed by the actions needed such as setting the speed.
The turnouts are set for condition continue which is indicated by a question mark.
What happens is that the position of each turnout is compared to the route set for each train. When a match is found only that track sensors is active. Obviously each route must be different.
Guest (5)
This page was generated in 0.411 seconds.
