Offline Peter Claesson
#1 Posted : 05 February 2019 22:00:21(UTC)
Peter Claesson
Hi all.
Anyone heard of that the S88 connection can fail in a CS2?
I've installed a 60880 feedback module and no response from it.
I have also tried a feedback module from LDT and same result.
Can my CS2 be broken?
It has worked before!
Thankful for any help.
Offline rbw993
#2 Posted : 06 February 2019 03:45:29(UTC)
rbw993
I believe you need a 60883 Link to connect the 60880 to the CS2. Then you must configure the 60883 in the CS2 setup menu to identify the bus (1 or 2) to which the 60880 is attached. The 60883 is bus 0 by default.
Roger
My mistake - I was thinking of the 60881
Edited by user 06 February 2019 16:34:51(UTC)  | Reason: Not specified
Offline PMPeter
#3 Posted : 06 February 2019 04:13:24(UTC)
PMPeter
Roger
I connect my Maerklin S88 decoders directly to my CS2 with no 60883. I believe you are thinking about the CS3.
Offline PMPeter
#4 Posted : 06 February 2019 04:16:23(UTC)
PMPeter
Originally Posted by: Peter Claesson Go to Quoted Post
Hi all.
Make sure that you have not lost the reference (O; brown wire; ground; or whatever you want to call it) connection to the inverted T terminal of the 60880.
#5 Posted : 06 February 2019 05:29:03(UTC)
Hi all.
Possible but unlikely.
As mentioned check the return reference.
The next most common thing to check is the cable.
- installed in the correct port
- installed up the correct way
- wire in cable head/plug broken
I am presuming that you have set up a "dot" on the layout board for the sensors to display.
And have tested by jumpering a wire to from a port directly to the "T"
#6 Posted : 06 February 2019 07:04:12(UTC)
Peter Claesson
I have never connected any wire to the T port before. It have been working fine.
How do i connect that, from track?
Offline PMPeter
#7 Posted : 06 February 2019 07:18:29(UTC)
PMPeter
Based on your question I am assuming you do not have a red (B) and brown (O) wire power bus providing power drops to your layout every 2 metres. If you did you could provide an O connection between any point on that bus to the T port.
If you have no distribution bus and you are using C track you can connect a reference wire from any of the O spade connectors below the track to the T port of the S88 decoder. If you have K track you could solder a wire to one of the rail joiners and connect that wire to the T port.
Without that reference connection your S88 will not work properly.
Offline PeFu
#8 Posted : 06 February 2019 07:26:35(UTC)
PeFu
Hi all.
Which LDT unit?
#9 Posted : 06 February 2019 10:05:20(UTC)
Peter Claesson
Hi all.
Which LDT unit?
RM-88-N
Offline PMPeter
#10 Posted : 06 February 2019 16:11:20(UTC)
PMPeter
It doesn't matter whether it is a LDT or Maerklin S88 decoder, the first S88 decoder in the chain needs to have the reference wire connected to the T terminal/port.
I was thinking that if you have a CS2 and are using S88 decoders you surely have other decoders on the layout for switches, signals, lights, etc. that require B and O power connections. If that is the case you can take the reference wire from anywhere where you have an O connection.
#11 Posted : 06 February 2019 22:43:22(UTC)
Peter Claesson
Anyone know i can get my cs2 checken in Sweden.
Nothing of the above seems to help.
Offline PeFu
#12 Posted : 07 February 2019 00:39:17(UTC)
PeFu
Is your LDT module connected as follows?
Are your modules connected via ethernet/patch cable, or via standard S88 cable? It could make sense to try the more reliable ethernet/patch cable variant. To connect the modules to CS2, you need the following items from https://tams-online.de:
1 x S88-15 (Short 15 cm Wire)
1 x S88-A-SL (Adapter)
Offline PeFu
#13 Posted : 07 February 2019 00:56:15(UTC)
PeFu
Actually, wiring could be different depending on module type, see below:
Using these modules, wiring is the same no matter if it’s the first or last module in the chain.
Offline PMPeter
#14 Posted : 07 February 2019 04:25:00(UTC)
PMPeter
True. If it is a LDT Opto version you need to connect the B (red) to the T terminal. However, he had already replied that it was the standard LDT RM-88-N version, not the Opto, so the O wire connection is the correct connection for either the Maerklin or LDT decoder.
The point I am trying to make is that you need to connect the appropriate wire (whether O or B) to the T port/terminal usually at the first decoder module regardless of the manufacturer. You cannot leave it disconnected and expect the S88 to work correctly.
Offline PeFu
#15 Posted : 07 February 2019 07:20:51(UTC)
PeFu
No he didn’t, and that’s why I asked the question of LDT model... Blushing
However, it seems like we have the same view on how the S88’s should be connected, and that is the only real important thing here. Cool
But I don’t understand how the setup can have worked, without the ”T” connection?
Offline PMPeter
#16 Posted : 07 February 2019 15:17:14(UTC)
PMPeter
Please refer to his answer in Post #9.
#17 Posted : 07 February 2019 16:18:41(UTC)
Peter Claesson
Thanks for your input guys, tried a lot yeterday. Still no response.
I think i have to send my CS2 and get it checked.
Offline siroljuk
#18 Posted : 07 February 2019 16:53:05(UTC)
siroljuk
Hi all.
What version of CS2 you have.In older Hardware-versions there was not galvanic isolation and s88may stop working for quite simple reason. In my older CS2 was that oldest version and in that S88 stopped working. Reason was that something was burned and Märklin Service changed the whole main board inside.
Jukka
Offline French_Fabrice
#19 Posted : 07 February 2019 21:01:29(UTC)
French_Fabrice
Just a shot in the dark:
-Are you sure the ribbon cable is correctly inserted in the CS2 ? Last time I did it, I shifted one pin, so nothing run
Good luck
Fabrice
Offline Elsleuth1
#20 Posted : 27 August 2019 21:10:31(UTC)
Elsleuth1
A question in the same vein. I have a CS2 with 16 S88s and 5 trains running automatically at the same time. All has worked perfectly for 6 months. Yesterday all the yellow dots on the CS2 track layout suddenly turned yellow at the same time. Why?
What would cause this? This morning same thing. Everything working perfectly, suddenly all S88s turned yellow causing my signals to all turn green. Ideas?
Offline Elsleuth1
#21 Posted : 27 August 2019 22:03:46(UTC)
Elsleuth1
I cleaned and organized my wiring to the CS2 paying particular attention to the S88 connection pins. Seems to work now.
#22 Posted : 27 August 2019 23:45:11(UTC)
How long is the wires from the s88's to the tracks where the detection is taking place? I'm thinking that someone with a radio telephone or ham radio started transmitting while nearby, and the signal got into your wiring. Keeping wiring short will help reduce this possibility.
Offline Elsleuth1
#23 Posted : 28 August 2019 02:55:23(UTC)
Elsleuth1
About 8 feet.
Offline Elsleuth1
#24 Posted : 04 September 2019 17:23:02(UTC)
Elsleuth1
It is happening again. All S88s on the CS2 track layout suddenly turned yellow at the same time. Why? Checked the T to ground. Cleaned all terminals. Still all S88s are yellow.
Edited by user 05 September 2019 02:05:16(UTC)  | Reason: Not specified
This page was generated in 0.698 seconds.
