Offline NeoMagicPulsar
#1 Posted : 03 February 2019 01:03:02(UTC)
NeoMagicPulsar
Hi everyone! I'm brand new to this forum and I hope you can help. I have three 6627 transformers (inherited) and I'm trying to test their output, but none of them are registering on my DMM. DMM is set to AC and I'm reading O-L and O-B, but getting absolutely zero reading. Am I overlooking something here or do I have three dead transformers? It would seem odd that all three would be dead on both circuits. HELP!
Thanks.
Offline PMPeter
#2 Posted : 03 February 2019 02:10:26(UTC)
PMPeter
Does the 6627 not have a red power on light on the top? Did it light up when you tested them?
#3 Posted : 03 February 2019 03:26:18(UTC)
NeoMagicPulsar
Thanks. Yes, all three have the red light on.
Offline PMPeter
#4 Posted : 03 February 2019 16:09:37(UTC)
PMPeter
OK so at least you know that the power from the outlet is getting to the transformer. If the transformer is working you should get a steady 16-17 VAC between the O and L terminals and variable 0 - 16 VAC between O and B as you move the knob from 0 - 100. If you get nothing as you indicated then there is something wrong inside the transformer or with your multimeter. Have you checked that your multimeter is working correctly?
thanks 2 users liked this useful post by PMPeter
This page was generated in 0.328 seconds.
