#1 Posted : 25 January 2019 21:35:51(UTC)
Marklin service have provided a copy of the 60970 manual
https://www.marklin-users.net/up..._60970_DecoderTester.pdf
it references a minimum mDT/3 version of 3.2.4 however in the last couple of days 3.3.0 has been posted on their website
https://www.maerklin.de/...3msd3/mdecodertool-mdt3/
The changelog history jumps from 3.2.3 to 3.3.0
KNOWN ISSUES
> If the mLD3/mSD3 are programmed via the Central Station CS2 to v4.2.8, the following must be observed!
A decoder project, with which mDecoderTool3 created from v3.3.0, needs the decoder firmware as of v3.2.0.0. The required decoder firmware as of v3.2.0.0 must be programmed before the decoder project.
Version 3.3.0 - 20.12.2018
- Feature: The mDecoderTool3 supports the new data structure (fds) v3 as of decoder v3.2.0.0, backwards compatible
- Feature: The mDecoderTool3 supports the new Märklin Decoder-Tester (60970)
- Feature: The mDecoderTool3 supports mSD3 track 1
- Feature: The mDecoderTool3 supports mSD3 track G
- Feature: The mDecoderTool3 supports a newly structured sound library on the Märklin server
- Feature: In the mDecoderTool3 the new function icons of the Central Station CS3 are available
- Feature: Acoustic feedback at the end of the programming process, successful or unsuccessful
- Improvement: Program the decoder (mLD/mSD, mLD3/mSD3) via the Central Station CS2 as of v4.2.8 (except sound on the mSD via the Decoder Tester (60970) and see known issues above)
- Improvement: Test the decoder (mLD/mSD, mLD3/mSD3) via the Central Station CS2 as of v4.2.8
- Improvement: Test the decoder (mLD/mSD, mLD3/mSD3) via the Central Station CS3 as of v1.4.0
- Improvement: Program and test decoder (mLD3/mSD3) via Decoder-Programmer (60971) with new Decoder-Tester (60970)
- Improvement: Update firmware or test decoder without having to create or open a project
- Modified: Firmware is programmed via the "Decoder/Update decoder firmware" menu
- Improvement: Revision of startboard, dashboard and detailboard revised
- Improvement: Arrangement and presentation of the programming paths improved and extended
- Improvement: All possible functions are displayed in the dashboard (mLD/mSD = 16, mLD3/mSD3 = 32)
- Improvement: Programming via a Central Station is possible with only one step (button)
- Improvement: Arrangement, presentation and operation of various CVs and parameters changed, revised and improved
- Improvement: Handling of the sound library generally improved and optimized
- Improvement: Playback and preview of sounds in mDecoderTool3 improved and optimized
- Improvement: Creating and changing sounds in the sound selection has been revised and improved
- Improvement: Revisit, improve and optimize sounds as random sounds
- Improvement: Multi station announcements can now be selected and set correctly
- Improvement: Incorrect sound file is recognized with a note and not transferred to the project
- Feature: In the sound selection, sort the sounds by sound number or sound slot
- Feature: In the sound selection simply change the sound number of a selected sound via context menu
- Improvement: In the functions mapping export/import improved and optimized
- Improvement: Completely reset functions assigned in the mapping
- Feature: In the mapping, the special function Random selectable and adjustable (mLD3/mSD3)
- Feature: In the mapping, the on/off delay of the physics. Outputs adjustable (mLD3/mSD3)
- Feature: In the mapping, the BUS functions (SUSI) are expanded to F20 (mLD3/mSD3)
- Feature: The mDecoderTool3 installer is now also available in French and Dutch
- Improvement: At the (first) start and in the help menu, the license agreement and the release note are visible
- Improvement: Various texts, terms and expressions revised
- Bugfix: Generally fixed minor bugs and improve stability, execution, and performance
Edited by user 27 January 2019 00:52:06(UTC)  | Reason: Not specified
#2 Posted : 27 January 2019 01:02:14(UTC)
If you installed the new update over an exisiting version it is probable that you will see duplicates in the Template
These appear to relate to the files in the fds directory.
the "V1" files seem to now be loaded under the "legacy" subfolder, but the new update does not delete them from the main list
Moving these ..V1 files out of the main directory will make the "New project" template dialogue clearer.
thanks 5 users liked this useful post by clapcott
Offline ktsolias
#3 Posted : 27 January 2019 23:31:39(UTC)
ktsolias
If you clear manually the result is this:
Definitely more clear
Costas
This page was generated in 0.262 seconds.
