Offline Ivan
#1 Posted : 20 January 2019 23:23:19(UTC)
Ivan
What`s the difference between 3307 and 3607 ?
Look the same outside and even Ersatzteile list is the same.
Thought 3607 are digital, but not all of them are described as such, i.e. digital.
It`s important for me to be ANALOG.
Offline Nigel Packer
#2 Posted : 20 January 2019 23:39:51(UTC)
Nigel Packer
3307 is Analogue (with electronic reversing unit). 3607 is Digital (c80 decoder).
Otherwise, the locos are the same.
Nigel
Offline Ivan
#3 Posted : 21 January 2019 09:43:39(UTC)
Ivan
Thank you,Nigel.
Is EVERY 3307 with factory built electronic Reverse Unit (EE 61486) ?
Or it`s originally with mechanical 208240 ?
I mean, electronic r - units are offered as new units to replace old mechanical units.
Also, mechanical reverse unit for 3307 is shown here:
https://www.maerklin.de/...elnummer=3307&lang=1
In short, I would like to acquire 3307 with OLD MECHANICAL r-unit, but will probably have to ask sellers about the particular loco.
Offline ktsolias
#4 Posted : 21 January 2019 10:19:16(UTC)
ktsolias
Originally Posted by: Ivan Go to Quoted Post
Thank you,Nigel.
The 3106 - 3107 are with the mechanical reversing unit
The 33xx have electronic reverse unit and 36xx digital
The exact type of the electronic reverse unit depends on the specific model
Costas
#5 Posted : 21 January 2019 11:07:09(UTC)
Nigel Packer
Thank you,Nigel.
That diagram is confusing because it doesn’t show the differences between the various models.
Also, the electronic reversing units still have the solenoid mechanism, but with an additional electronic circuit to suppress the “kangaroo” jumping when reversing the loco.
Even the 3607 with original c80 digital decoder will run just as well on an analogue layout.
Nigel
This page was generated in 0.407 seconds.
