Offline danmarklinman
#1 Posted : 04 January 2019 18:38:53(UTC)
danmarklinman
I have a new 60760 decoder, and I have the instructions for it. I want to use it as a function decoder for my driving trailer. The only trouble is. What do I do with the white and black wire? What are they for. It says function F2 and F3. But know clear instructions on what for? Also it says it has two orange wires but only one? The common return for head lights? Can I use the motor wires to power the coach interior lighting? The green and the blue? Any ideas please. Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 04 January 2019 18:58:33(UTC)
The motor wires cannot be using for the interior lighting!
Use the orange wires.
The orange wires are permanent function while the headlights are function F0.
What black and white wires?
#3 Posted : 04 January 2019 19:01:31(UTC)
By the way...you did write 69760 as post but in the topic you write 60760...
#4 Posted : 04 January 2019 19:19:27(UTC)
danmarklinman
Thank you for your reply. Yes I did mean 60760👍 Yes the decoder has also a black and a white wire sticking out the black bag? Thanks Dan
Wiking fan
#5 Posted : 04 January 2019 20:29:41(UTC)
The instructions for the 60760 decoder from Märklin describes the wires coming from the decoder:
The yellow and grey wires go to the lights that are activated direction dependent on the controller, the orange wire is the common for those lights (the +ve lead).
If you give this decoder the same address as the one the loco, you could have different lighting schemes based on direction, such as activating the tail lights as red or white depending on if the loco is going forwards or back.
No white and black. I wonder if there was a different variation of this decoder in the past.
#6 Posted : 04 January 2019 20:33:20(UTC)
danmarklinman
No white and black.
Thanks for your help Minok, much appreciated. Yes that’s the same diagram I have! What i can’t work out is, why are the white and black wires as well. 😱
Wiking fan
#7 Posted : 04 January 2019 21:11:59(UTC)
Why not ?? Blink
#8 Posted : 04 January 2019 21:21:44(UTC)
Why not ?? Blink
Indeed, if you give it a separate address you can control the intensity of the lights...
Which of course gives me an idea... If you have several onboard train lighting in different trains with the same digital address you can control the intensity in all those trains with one address depending on how much lights you want regarding train room darkness an such ambience factors by setting the "speed" for the decoder... Just a thought... Smile
#9 Posted : 04 January 2019 21:45:12(UTC)
And a rectifier if the light is LED......... BigGrin
I don't think "reverse light" is a good idea; it might ruin your dark suckers. LOL
#10 Posted : 04 January 2019 22:21:44(UTC)
Yes, but they use orange wire which must please Per no end!
There are some undocumented function outputs on this decoder - the topic has been discussed in the forum many times.
See https://www.marklin-user...locos-with-60760-Decoder
Offline kgsjoqvist
#11 Posted : 04 January 2019 22:42:30(UTC)
kgsjoqvist
Probably the black and white wires have been soldered on the decoder afterwards. As delivered this decoder has only motor + lights front and rear. If the loco is MM only as well, it is easy to use the same address and get automatic light changeover with direction.
thanks 2 users liked this useful post by kgsjoqvist
Offline Ross
#12 Posted : 05 January 2019 01:45:19(UTC)
Ross
Hello Juhan/All
I have started to have variable LED lighting in my trains and you can find the article below
Variable LED lighting decoders
I hope you find it useful.
Why not ?? Blink
Edited by user 02 January 2025 00:08:14(UTC)  | Reason: Link corrected 02-01-2025
Ross
thanks 3 users liked this useful post by Ross
Offline Ross
#13 Posted : 05 January 2019 01:49:08(UTC)
Ross
Hi David/all,
I have used this poor engine decoder for a coach lighting project
Thunder box LED lighting
Edited by user 02 January 2025 00:09:40(UTC)  | Reason: Link corrected 02-01-2025
Ross
thanks 4 users liked this useful post by Ross
#14 Posted : 05 January 2019 08:50:58(UTC)
I have used this poor engine decoder......
Basic, but I would never say poor!
Believe me having 128 speed steps in a decoder is way overrated, you have turn the controller knob half a dozen times just to get a loco with one to stop which is a real pain! You don't have this problem with a 60760.
Like Ray, I think they are great kit for a cheap loco conversion that you don't want sound in and have no functions other than lights.
Offline Ross
#15 Posted : 05 January 2019 09:36:09(UTC)
Ross
Hi David/All,
Please read my reasons for stating that this decoder is poor see page 28 of my strange bits log. Blink
Strange Bits Log Part 1
Please note the date I wrote this comment. It may well be an early version of this decoder, but once I have had a bad experience I don't want to repeat it.
As for 126 speed steps in a in a MFX decoder I agree but I never mentioned it. Confused
Edited by user 02 January 2025 00:10:51(UTC)  | Reason: Link corrected 02-01-2025
Ross
#16 Posted : 05 January 2019 09:40:21(UTC)
They have undocumented F1 and F3 outputs - and the logical function ABD off.
And when used as a function decoder, the motor outputs can most likely also be used for lights and other accessories.
With a CS2 all decoders require the same amount of rotations, whether they have 14 speed steps or 126.
Good controllers let you choose 32 speed steps for mfx decoders or 14/28 speed steps for DCC decoders.
14 speed steps are very basic, I prefer 27/28 speed steps (which the 60760 does not have). 126 is too much for my taste, but I don't mind having an unused feature in the decoder.
#17 Posted : 05 January 2019 11:02:29(UTC)
No, I realise that but it is a particular bugbear of mine!
Offline Ross
#18 Posted : 05 January 2019 22:31:05(UTC)
Ross
Hi David/All,
On the ECoS you can set MFX decoders to be mapped to just 28 speed steps, is this possible with the CS2/3?
Ross
#19 Posted : 05 January 2019 23:02:25(UTC)
Not possible with a CS2.
This page was generated in 0.912 seconds.
