Offline applor
#1 Posted : 02 January 2019 13:14:47(UTC)
applor
A bit of a tricky one but maybe someone knows so I will give it a shot.
I have a Marklin MFX railcar VT 8.5 (39080) that I want to permanently swap its forward/reverse. The controller would be showing forward but in reality the railcar drives backwards.
I am hoping there is a CV bit that does this change for Marklin MFX decoders but I don't know if they do or what CV it is.
ESU for example have CV29 Bit 0 which reverses the direction of travel (forward becomes reverse).
The description however says it is only relevant for DCC standards and so I highly doubt it would be the same or even work for a Marklin MFX decoder.
You may be thinking I'm daft at this stage as to why?
Well the reason is the 39080 railcar has the front bogie powered with both axles having traction tyres.
Unfortunately this means I can't run this train with automation as the S88 detection points don't trigger until the rear bogie!
Easy solution is to just run it permanently in reverse.
Edited by user 13 November 2019 22:14:49(UTC)  | Reason: Not specified
#2 Posted : 02 January 2019 13:22:55(UTC)
The 39080 has an ESU decoder. And somewhere in the mfx configuration space there is a bit that swaps the direction. Do you have a Central Station?
The ESU documentation for CV 29 indicates that bits 1 and 5 are only relevant for DCC. The direction bit is bit 0 and it is relevant for mfx.
Offline applor
#3 Posted : 03 January 2019 00:16:06(UTC)
applor
Yes I have a CS2 (and ESU lokprogrammer). So you are saying that CV 29 bit 0 for directional change is relevant for MFX as well and what I need to change?
I will attempt change of it today and post how I go. Thanks for your help!
EDIT: Changed CV29 using my CS2 and it worked. Forwards and reverse are now swapped Cool
Edited by user 03 January 2019 05:43:31(UTC)  | Reason: Not specified
Offline applor
#4 Posted : 03 January 2019 12:49:21(UTC)
applor
Well it turns out there is a remaining issue that was unforeseen:
When the locomotive temporarily loses power, it remembers its existing speed but in the wrong direction!
I've found when testing that as the railcar drives over a tiny spot on my track and temporarily loses power, it then begins driving at the same speed in the opposite direction.
This means it then hits the same dead spot again and then begins driving in the opposite direction.
It therefore remains permanently stuck at the dead spot as it keeps driving back and forth over it again and againLOL
Laughs aside, it's rather annoying.
Looking at the manual, do you think this could be fixed with CV124 Auxiliary settings - Store direction (Motorola®)?
#5 Posted : 03 January 2019 13:46:25(UTC)
Brilliant BigGrin
You have invented a "dead spot detector", which shows you exactly where the dead spots are BigGrin
thanks 4 users liked this useful post by Purellum
#6 Posted : 03 January 2019 14:07:04(UTC)
I suggest to give that CV a try.
Offline applor
#7 Posted : 04 January 2019 04:31:29(UTC)
applor
I am sure this is it but CV124 does not appear in the list after choosing edit CV in the locomotive page of the CS2Confused
#8 Posted : 07 January 2019 13:31:37(UTC)
I can try using my lokprogrammer to change the CV. For some reason though my lokprogrammer can never read CV's from any decoder I've tried and I am hesitant trying to blindly write to it.
The Lokprogrammer has problems with C Sine locos. You should be able to change the decoder settings when you temporarily install it in a loco with a conventional motor (or the ESU decoder tester).
Don't try the DCC CV screen, read the complete decoder settings with the Lokprogrammer software.
#9 Posted : 07 January 2019 20:44:57(UTC)
Here's a screenshot of the CS2 PC software:
The bit to set is "Richtung" under "Memory B" on the "Misc" tab.
I didn't check a real ESU decoder on a real CS2, but IIRC this screen will also be shown for those.
Offline applor
#10 Posted : 08 January 2019 11:06:01(UTC)
applor
That appears to have done the trick - thanks so much Tom!
Offline applor
#11 Posted : 11 January 2019 07:28:01(UTC)
applor
edit: nevermind. It is working properly, I happened to get a ghost event on a different train exactly when the VT 8.5 happened to be at the dead spot and I thought the problem was still there. Blushing
edit edit: I retract that previous edit, I did see the VT8.5 do another reverse on me. I am not sure on the trigger though as it was in a different location. I need to test further.
Edited by user 19 January 2019 05:20:54(UTC)  | Reason: Not specified
Offline applor
#12 Posted : 02 November 2019 02:27:25(UTC)
applor
Finally started running my trains again ready for some guests and since the track is a bit intermittent I am having massive problems with this VT 8.5 as it is constantly reversing whenever it hits a rough spot.
I have a feeling it may have to do with the relay activated dual sliders.
Offline applor
#13 Posted : 13 November 2019 22:16:27(UTC)
applor
Decided to bite the bullet and just swap directions with the wiring.
Motor L and R were swapped along with the front/rear lights. I also bridged the slider changeover relay so now both sliders are always active. Removed the swap direction bit.
All mods are reversible and problem permanently solved.
Offline dickinsonj
#14 Posted : 28 February 2020 16:28:37(UTC)
I want to pick up here on a topic I started in an HO section thread about my 37604/43114 VT 11.5 train set. I should have just started in the digital section but I was hoping for a simpler solution, which was not to be. I was pointed to this thread by Eric (@applor) in my earlier thread: https://www.marklin-user...-37604-Headlight-Problem
About 9 months ago I put my 37604 away in perfect working order. Yesterday I cleaned and oiled the motors and wheels. I did not apply power to my track until the entire train was connected, but when I did the direction of travel was out of phase with the lights. It is also out of phase with the slider, taking power from the motor car with the white headlights, which is now the rear unit in the train.
Antonio (@amartinezv) suggested separating the power cars and toggling the motor direction, which made sense. Unfortunately the reverse relay is mounted on a board which also hosts the decoder mounting board, so that simple approach did not work. I knew that there were CVs associated with lighting and motor direction and this thread helped me find them, where I was sure a solution might lie.
Here us a summary of what I have tried so far:
1. I did a decoder reset, which unfortunately made no difference
2. I toggled Motor CV#29 bit "Motor/Licht" on and off with no effect
3. I toggled Misc CV#74 Memory B, bit "Richtung" on and off with no effect.
I have no idea why changing those bits in the CVs did not have any apparent effect. I went back and checked to see that my CV changes had persisted by reloading them and they had remained where I had set them.
At this point I can't think of anything else to do but swap the motor wires. I don't see a need to bridge the slider relay because it stays perfectly in synch with the lights. If the motors just ran in the opposite direction it would be working fine. But that seems like a poor solution because who is to say when the direction state will toggle again? I almost need small wire connectors that would let me swap motor wires in a plug in fashion, but I have never found male/female connectors for wires that small.
If anyone has any ideas of things to try beyond what I have done so far I would love to hear them. Otherwise it is back into its box for my much loved VT 11.5 train. ThumbDown
Offline thing fish
#15 Posted : 28 February 2020 20:10:43(UTC)
thing fish
Turkey
Put it back into the closet, wait for 6 months and check again LOL
Joke aside, I'm very much interested in the solution as I have the same beauty and I'd be very very upset if this kinda thing happens to it.
C.
Offline dickinsonj
#16 Posted : 28 February 2020 20:22:39(UTC)
C.
I hear that.
This train is a all time favorite of mine and I hate to have it not working correctly. I also have several other trains with that same slider switchover and now I wonder how long until one of them fails as well. Actually, consider the ICE4 with two sliders and interior lighting that can be turned on and off as well as changing its color. How long do we all think that is going to work as designed?
Offline thing fish
#17 Posted : 28 February 2020 21:56:33(UTC)
thing fish
Turkey
... How long do we all think that is going to work as designed?
Until, I hope, we all become electronics engineers, and master solderers!
Well, I take this type of petty repairs as the lighter part of the hobby. I enjoy messing with low cost locos for mods and weathering and all; but not the 37604, please.
C.
Offline dickinsonj
#18 Posted : 01 March 2020 17:13:10(UTC)
I just wanted to close out my part of this excellent thread. I tried to shift the discussion about my 37604 to this thread but it did not work. I did receive a lot of useful suggestions in the other thread, although ultimately none of them helped.
So I have now tried everything that I (and others) could think of and have given up and packed my VT 11.5 away. Short of doing what Applor did to his loco I don't see anything else to try.
RIP my pretty train. Crying
Guest (10)
This page was generated in 0.656 seconds.
