Offline bygger01
#1 Posted : 01 December 2018 14:53:44(UTC)
bygger01
There is a large diff. between my large steamers ( like BR 01/03/53 ) with tenders and my diesel locomotivs when it comes to stops for dirty tracks.
Do any of you see, that the steamers have many times more stops.
And do you think some x-stra weight in the tender will help ?
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
#2 Posted : 01 December 2018 16:14:02(UTC)
Keeping the tracks clean should avoid this. Also clean the slider from time to time.
Offline costing
#3 Posted : 01 December 2018 17:08:48(UTC)
costing
For me the problem usually is with the center rail. Any dirty point leads to a full stop. Three suggestions for you:
- install keep-alive capacitors (not obvious in M* but can be done by following the traces from the decoder plug, you usually find easy to access pads on the main board)
- clean the center rail, then glide a graphite bar (soft pencil) over it, it helps a lot. This you can test locally on the area that gives you trouble.
- don't let the oxide form, run more often :)
.costin
Offline bygger01
#4 Posted : 01 December 2018 21:18:04(UTC)
bygger01
.costin
You are writing - glide a graphite bar (soft pencil) over it - I have never hear about it, so can you help with a link ?
Such a pen could also be good for the Märklin turntable !
Offline costing
#5 Posted : 02 December 2018 12:19:02(UTC)
costing
I use a graphite bar as you can see in the bottom right corner of the box. A little goes a long way :)
I apply it on both the tracks (it helps mechanically cleaning it from paint residues as well) and the center pins. The pins are very harsh on the graphite bar, use an even lighter touch on them.
As for references, here are a few:
https://model-railroad-h...irty-rails-with-graphite
https://model-railroad-hobbyist.com/node/17181
search the forum for many other references to using graphite for this purpose.
.costin
thanks 2 users liked this useful post by costing
#6 Posted : 02 December 2018 13:09:41(UTC)
Hi Costin
Very interesting. I will try. Before I was using a slider-shaped wood covered with 1000 abrasive paper.
Offline costing
#7 Posted : 02 December 2018 14:23:42(UTC)
costing
I'm trying to avoid any abrasive methods as the micro scratches increase the exposed surface area and provide grip for dirt to catch on to. Or so the experts say :) Anyway, it's a very quick process, give it a try and see how it works for you.
.costin
thanks 1 user liked this useful post by costing
Offline bygger01
#8 Posted : 02 December 2018 19:58:23(UTC)
bygger01
Graphite bar - I had never heard about them ......
They lie together with pencils, so may the bars be used for drawings ?
I can also see that one of the pencils had been used and is a soft 6B, are you also using them for the same ?
#9 Posted : 02 December 2018 21:15:39(UTC)
I use a Roco rubber for track cleaning.
Offline costing
#10 Posted : 02 December 2018 21:36:11(UTC)
costing
Yes, this is a drawing set. I think the correct term is graphite sticks, you can see them in action here:
:) Not for this purpose. While the core of a pencil is the same material, the wood around it makes a pencil inconvenient to use. One would have to continuously sharpen it ... But sure, you can use a pencil on a test zone.
.costin
#11 Posted : 03 December 2018 14:54:54(UTC)
Another expression might be 'charcoal stick' although technically they are not charcoal, but used for 'charcoal' drawings.
Offline skeeterbuck
#12 Posted : 05 December 2018 16:08:23(UTC)
skeeterbuck
I use a carpenter's pencil with a "V" notched in the center to help keep it on the rails. I've notice much better running since I started using graphite on the rails. ThumpUp
Offline skeeterbuck
#13 Posted : 05 December 2018 16:10:03(UTC)
skeeterbuck
A artist charcoal stick is NOT graphite. Be careful!
This page was generated in 0.390 seconds.
